Question about SanDisk Sansa m240 MP3 Player
It wont work
I tried everything but it wont work all it does is at the start says sansa and m240 and 1.0gb and at the to it says v4.0.44a i was playing music then i paused it for a minute and when i looked back down it off when i turned it back on it stayed at the sansa
I have the same problem and you can't put the player in MSC mode because it is stuck.
Posted on Jun 05, 2007
Go to sandisk.com and download the updater. It should do a rescue and fix the firmware. Download the file, install it -- without having the player on the system. MAKE SURE you put the player in MSC, if you can.
Posted on May 30, 2007
SOURCE:
Sansa e250 dispyaying synchronize to continue music subscription
If your music has DRM it willonly allow you to sync once. they want you to repurchase the music. Try syncing music that is DRM free. If the new file work that is your problem.
http://www.sansaworldmp3.com/
http://www.sansaworld.com/
Apr 04, 2009 | SanDisk Sansa e200 MP3 Player
Can't add or remove music off my Sansa Rhapsody 2GB
first try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
Music appears in the folder, not on the Sansa
try formatting it. to do that, simply scroll down to settings, and in settings hit format. you'll lose everything that was on it tho, if that don't work then try updating.
Nov 07, 2008 | SanDisk Sansa e260 MP3 Player
Audio is messed up!
First, make sure you didn't download an instrumental.
Second, make sure the files are in a format that the player recognizes.
If both conditions hold, then upgrade the firmware - you have a corrupt DB.
Sep 08, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e260 gone retarded 4.0GB
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 28, 2008 | SanDisk Sansa e260 MP3 Player
Wont open music folder
The folder option won't work particularly well - use Windows Media Player instead. If you continue to have problems:
Go ahead and do this, in case the DB is corrupted:
Feb 29, 2008 | SanDisk Sansa e250 MP3 Player
IT wont turn on
tyr holding both the power button and the play button for 20seconds at the sametime
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
My video doesnt work..
Download most recent version of Quicktime - will give you right codecs
Nov 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa music transfer problem
Thats probably the best idea to erase everything and start anew. You can format the device in My Computer>Device Name (e250)>Right Click on it and select Format. This will erase everything on your device. If you are getting Bad Track from just a few songs, just delete them as they may be corrupt. Also, you need to keep some free space on the device to create the database. Keep at least 6MB free for every GB. Best of Luck.
Oct 08, 2007 | SanDisk Sansa e200 MP3 Player
It's frozen
i had the same problem and they told me it was a firmware problem on models received around xmas.
Apr 04, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
