I HAD TV ON. EVERYTHING WAS FINE. ALL OF A SUDDEN, IT BECAME SNOWY. LIKE THE CABLE WAS OUT. SO, I TRIED UNHOOKING DIGITAL CABLE BOX. AND HOOKING CABLE STRAIGHT TO THE TV. STILL, IT WOULD NOT GO ANY HIGHER THAN CHANNEL 13.
  • LYNN GREENE Dec 07, 2008
    THANKS FOR ALL OF YOUR INPUT, ON A SOLUTION.
    I TRIED SEVERAL TIMES. BUT, STILL NOT ABLE TO GO ABOVE CHANNEL 13.
    I GOT TO LOOKING AROUND. AND I FOUND A RESET BUTTON. I HAD TO PRESS IT, 3 TIMES.
    THIRD TIME WAS A CHARM. IT START SCANNING ALL CHANNELS.
    THANKS, AGAIN
    LYNN
    Welcome Back:
    Visited the website for 2 consecutive days.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} With the snowy problem; it does sound like aerial has disconnected. Try putting your finger over the aerial socket hole behind the TV while TV is on (using your self as an aerial). If snowy disappears then you have an aerial plug/wire disconnection problem.
Posted on Dec 06, 2008
Connected the coaxial cable to the tv but got no channels. the tv turns on but all I have is snow
Some possible things to check:
1. Are you trying to receive off-the-air broadcasting? If so, you'll need a digital converter box. This set doesn't have a digital tuner, so there won't be any channels for it to receive without the converter.
2. Are you connecting a cable from a cable converter box, satellite receiver or FiOS set-top box? Your TV will need to be set to channel 3 or 4 to see the signal from the device.
3. Make sure the center wire in the plug on the end of the cable isn't bent over, and that it extends far enough (about 1/8 to 1/4-inch) to make a good connection.
4. Do you know for sure that the cable you are connecting is working? Is there actually a signal on the cable? It may be disconnected somewhere else (at a splitter, for instance) or there may not be any signal source.
5. Have you tried another TV to test the cable? If the cable works with another set, the tuner or antenna connector on the snowy set may be bad. If the cable connector is tightened too much when hooking it to the TV, the connector may be damaged and this can cause the snow.
Start by checking with a known good TV. If that one is snowy, you can check the other possibilities. If it works, you'll know the problem is in your set and can decide what to do (repair or replace).
Hope this helps! Thanks for using Fixya.
Nov 08, 2010 | Toshiba 27AF42 27" TV
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
I have 3 digital tv's one in the lounge/bedroom and kitchen for some reason last night, the tv's in the bedroom and kitchen lost all digital channels and the analogue channels were very poor to view snowy...
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
Sep 02, 2009 | Televison & Video
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
Local tv channels come in snowy
you have cable and the stations are still snowy? could be tuner do you have a box or directly hooked up to tv, try unhooking box if you have one and directly hook it up to tv if you havent already done so
Jan 21, 2008 | Zenith C32V37 32" TV
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
