LOW SPEED COOLING FAN APPEARS NOT TO BE WORKING WELL
Change the relay, situated in a black plastic box up in front of the battery. Costs about 7 pounds / 11 dollars USD on ebay and takes 30 seconds to do. Until you get it fixed, protect the engine when temp get over, say, 90 degrees celcius, by opening up your side dash vents, turn the in-car fan on max and the temp up to max. The hot air will go directly out the windows and you will see the temp gauge drop back to about 80 degrees. I did this for a year until I figured out the relay needed replacing.
SOURCE: Cool fan low doesn't work. Doesn't appear to be
It needs to have the blower motor resistor card replaced.
It still works on high speed because on the high setting the voltage does not go through the resistor.
The resistor is mounted beside the blower motor and is easy to replace.
There you are, thank you for using FixYa.
KL
SOURCE: Hi,this car is actually a Vauxhall Meriva, but
should be behind the plastic cover below the wipers on passanger side i think but be carefull when you remove the top of the box cause it will set the alarm off DONT LEAVE THE KEYS INN THE CAR it might lock depending on the system
