Question about LG 42LC2D 42 in. LCD HDTV
Viore DLP TV keeps shutting itself off
Our t.v. is 1 1/2 yrs old. and it is shutting itself off. Sometimes right after it is turned on and also after it has been on awhile. It is getting worse.
  • pocketts Dec 14, 2008
    my LG 42inch keeps shutting down too I have too turn it off and back on again and its getting worse
    Problem Solver:
  • 16 Answers
Contact lg at 800-423-000. they may cover the repair. They might charge you a small trip fee and cover the part. sounds like the pwr supply is shutting down.
Posted on Dec 07, 2008
VIORE DLP goes off 30 seconds after i switch it on
Listen closely at the rear of the set for any noise from a fan. Most projection sets have them to cool high temperature areas common in these and if the fan fails, the set will shut itself off before any heat damage results. If you hear nothing, use a portable fan directed at visible openings in the lower cabinet and see if this delays the shut-off of the set. If so, the fan is likely dead.
Jul 30, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My 50" Viore DLP Television has white dots showing
Bad Light Engine/Optical unit Assy Block
Encompass Parts Distribuiton 1-800-638-3328
UED 1-800-648-6657
Dec 14, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My viore tv wont stay on it keeps going off by its
Ur tv the projection lamp,inside the tv now,been on an in used about 4 or 5 hours a day,the bulb been inside tv about 1 1/2 or 2 years?The projection lamp life is over,reqiure changing?Turn tv on hear alot of clicking too?The board call the Ballast board also require changing too,this Ballast board help to ignite the projection lamp.
Jul 24, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My viore 50" dlp tv keeps turning off every few minutes
Ck Fan that cools Lamp if it stops running then it is defective But it could be you just need to Replace Lamp Call Mats 1-800-628-1118 and Look up online Encompass Parts for your TV,this is there # 1-800-638-3328 Also look on E-Bay found Lamp for my DLP for 85.00 thier.
Nov 18, 2009 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I have a viore 46 dlp
check your cooling fan. if the fan is not working or to dirty the light housing will build to much heat and the unit will shut itself down .
Nov 09, 2009 | Televison & Video
My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Jul 20, 2009 | Televison & Video
We have a VIORE DLP TV Model RPT50V24D, Dimensions: 46.54 x 14.13 x 34.25 inches, about 1 1/2 yrs. old. Our problem is that it is shutting itself off, sometimes right after we first turn it on and also...
I have the same TV, and this worked for me, and I never had the issue again.
Go into Settings, and turn off the "GAME MODE"
Mine has never turned off again.
Doug
Dec 06, 2008 | Televison & Video
Viore DLP TV
The lamp is most likely over heating. Check the fan in the lamp assembly compartment. Its located in the rear of the tv... try removing the lamp compartment and replacing the fan.
A quick fix is to put a small 7-10 inch box fan with its back flush to the lamp
compartment's vent - this will draw the heat out.
Sep 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung DLP HL-P4663W
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
LG 42LC2D 42 in. LCD HDTV Logo
415 people viewed this question
Computer Repairing
Computer Repairing
