Question about HP PSC 1315 All-In-One InkJet Printer
WHEN I TURN ON THE PRINTER IT STARTS TO PRINT THE ALIGNMENT PAGE
HP1315 ALL IN ONE
  • Boogerhead01 May 11, 2010
    Starts to print the ... ?
    Guru:
  • 731 Answers
Hi Mahdavi,
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Posted on Dec 06, 2008
HP officejet pro l7680 all-in-one: when attempt to print, printer says "aligning printer" for a while, will print one page, then print an alignment page, and then states "alignment...
You could try to turn off printer.
Unplug printer from electrical outlet.
Wait at least 15 minutes, this will let the printer to clear memory.
Plug back in printer and turn on. Do a cleaning cycle.
The cleaning cycle will insured a good alignment page.
Align printer.
Jan 11, 2011 | Office Equipment & Supplies
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
Prints test page when turned on
Does it Print Self Test Page or Does it print Alignment Sheet ?
Remove the Cartridges
Clean the Contacts on Cartridges with lint free cloth ( golden contacts )
Disconnect the USB Cable from Printer
Insert the Cartridges
It should go thru Alignment process - complete the alignment process
Connect the Cable to Printer
Turn off/on the printer it should not print the page.
Jun 25, 2010 | HP PSC 1315 All-In-One InkJet Printer
Alignment page prints every time printer is turned on. HP1315 on Windows Vista Home Premium.
Take the test page ( also called : alighnment page ) that always prints when you switch on the printer and place it face down in the scanner.
Then press the scan button on the printer itself.
(this is the button at the bottom of all the buttons on the printer/scanner.)
Make sure that the printer scans the test page.
( sometimes you press the butoon and it doesn't scan )
( it makes a scanning noise when scanning succesfully )
Then it will stop printing the test page ( alignment page ) ever again.
Sep 18, 2009 | HP PSC 1350 All-In-One Thermal Printer
Always starts up and does an alignment page.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
    after the alignment page prints then place the alignment sheet on the scanner glass and press the ok button
Jul 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
Steps
Thanks
Rizwan
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Alignment page every time
- after it printed an alignment page
- face the alignment page on the scanner and press ok..
- then try to print from the computer.
- try to turn the printer off and on again if still it will print an alignment page.
Sep 05, 2008 | HP PSC 1350 All-In-One Thermal Printer
Alignment page prints whenever I turn on printer. HP PSC 1401 Mod:Q7299A Ser:CN59622173
when you turn your printer on and it printed the alignment page, try to scan the alignment page. and then try turn it off and on if it still print an alignment page.
Aug 28, 2008 | HP Office Equipment & Supplies
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
262 people viewed this question
Seeker5211
Seeker5211
