Question about Generic Memory 10-Bay Matrix ATX Window Case w/450-Watt PS
Can not find location to plug in my case wire plugs on my mother
My matrix ATX case has some wire conectors which i can not figure out where to plug on my Gigabyte GA-MA78GM-S2H mother board? the wires in question are marked (gray-return R, blue-return L, green-spk out R, white-spk out L, black-ground, yellow-mic bias, ppink-mic in?
there are also 8 other wires (groups of 4), red +VCC, white -D, green +D, black ground, and the other 4 are colored and labeled the same?
  • 104 Answers
You will need to take out your motherboard manual and look thru it for the usb header and audio header for the correct pinout in order to plug those in
Posted on Dec 12, 2008
Name of wire based on color coding wire
Special (only on the ATX conector)
-Green is PSon(put a wire between green and black to turn the power on)
-Gray is PWRGOOD
-White is -5V(optional)
-Blue is -12V
-Purple is 5VSB(Always on when the PSU is plugged on)
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
-Black is Ground (0V)
Dec 20, 2012 | Lite On LiteOn 204Watt PA-4022-6B Power...
Wire name based on color coding wire
-Gray is PWRGOOD
-Blue is -12V
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
Dec 20, 2012 | Lite On (PS-5101-2B) (ps51012b) 145-Watt...
New Phantom case. MSI P67-GD80, I7-2600k, 16g ram. Fans and leds come on go off and come on continually.
You sound like you built it yourself. I have the same case. what you need to do is check the wire that are preziptied to the back of the computer and make sure all those that come from the fan controller are plugged into the sidefan slots tightly, otherwise they will slip in and out causing the fan controller to not recognize the fans(turn off the leds). Most of the problems that happen with this case come from wires not being plugged in hehe.
Jun 09, 2011 | NZXT Phantom PHAN-001RD Red ATX Full Tower...
Ok! I have an ak32 shuttle mother board I'm wanting to upgrade. Over the years I've added newer graffics, audio, extra usb ports,and earthnet card. I built the pc in 2002. I had a cooling fan recently go...
the case isnt amd athlon 2100 xp, thats the processor, the case is either a atx or micro atx case, so refer back to the case and find out if it is a atx case or a micro atx case, then find a micro atx or atx motherboard so you dont have to replace all of your components
Jan 05, 2010 | Computers & Internet
No manual for my chaintech spt800 motherboard
I have a manual. Somehow, I managed to keep track of it.
Contact me at storm5510@gmail.com.
Mar 10, 2009 | Chaintech : SPT800 P4...
HOW DO I CONNECT THE CASING TO THE MOTHER BOARD
what is it you want to do ..install the mother board ? or the wires to connect the usb ect ?
Jan 17, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
Raidmax Sirius case not turning on
Recheck the wiring. Make sure the fans are all plugged into the proper place. Then try reseating the RAM, video card, & cpu. Make sure you have applied a good thermal paste between cpu & heatsink as overheating can cause the system not to boot. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Bestec ATX-300-12EB3
There should be 12v coming from the yellow wire and 5v from red. Open PC and use a multimeter to check the voltage output connect negative probe to the power supply casing and the positive to the red and yellow wires from the molex connectors. If the readings are below the mentioned voltages then the PSU is faulty. Note if readings can be round off to the given values then the output is fine. cheers.
Nov 22, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Generic Memory 10-Bay Matrix ATX Window Case w/450-Watt PS Logo
214 people viewed this question
Top Generic Memory Computers & Internet Experts
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
