My television tevion with model T1495BD has a buzzing sound
Once you turn the tv on the buzzing sounds start even the volume is on zero.
5 Suggested Answers
  • 65 Answers
SOURCE: Toshiba color television 36A12
if you are using a cable box make sure the cable box remote volume is also turned up go into the customer menu on the tv and verify that the speakers are on under the audio settings
Posted on Dec 09, 2006
SOURCE: buzzing
The SDT-SH-112DM is a SPST Form-1A relay. It was hard to find, so I went to Radio Shack and bought a similarly sized and rated relay that was a DPDT (also from OEG). broke off the NC pins, joined (soldered) the switch source lines & removed the unused NO pin so it would fit in the drill holes... works fine!
Posted on Oct 14, 2008
SOURCE: sanyo tv ds25390 buzzing sound
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
Posted on Mar 11, 2009
SOURCE: Buzzing sound coming from TV
I just started having the same problem. it comes from a large capacitor changed them but the new ones still make the noise.
Posted on Jul 30, 2009
SOURCE: Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Posted on Sep 22, 2009
Tv will not turn on
sounds like you have a fried main power board in your TV... Unfortunately technician replacement of this board will cost nearly as much as replacing your tv.
May 03, 2015 | Tevion Televison & Video
WHEN MY FRIEND'S TEVION TELEVISION MODEL No. 3241TS IS TURNED ON, A PICTURE FLASHES ON THEN DISAPPEARS. SOUND IS STILL ON BUT NO PICTURE. THE SAME APPLIES IF CONNECTING AND PLAYING A DVD.
That sounds like the inverter board. I would go online and search for the inverter board for that model TV. Replacing it is a very simple task once you take the back of the TV off.
Mar 01, 2015 | Televison & Video
Buzzing sound + Tv picture is very weird.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS.. AND ALSO ALL FUSES AROUND IT .THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
GOOD LUCK
May 23, 2010 | Polaroid TLA-01911C TV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Buzzing sound
The sound is a result of the faulty CRT base, and you will have to replace the base socket. Make sure you by the exact same type of base, and if you are not a techie, get a qualified technician, this is not a costly problem.
Jan 17, 2008 | Samsung HL-P6163W 61" TV
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Buzzing noise in the TV
The Samsung HLN5065 is a DLP TV. Color wheel or fan. Thefan is the last to turn off. That's how you'd check it. Tube
Oct 21, 2006 | Samsung HLN5065W 50" Rear Projection...
Audio noise on cold start
hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
Mar 19, 2006 | JVC AV-32750 32" TV
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
