Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Red haze when the screen is dark there is a red haze in the center of my 60v500. the tv is 4 yrs old. it is perfect other wise..
  • 5 more comments
  • sexymarie628 Dec 07, 2008
    when dark colors come on they look very red
  • Anonymous Dec 13, 2008
    all my black areas are red and my white areas are green need solution
  • sjudkins5 Dec 14, 2008
    I have this issue also. It started as a very small spot at about 2 years then gradually got as large as the entire screen now that it is 4 years old. Dark areas are red and light areas are greenish.
  • nariojr Dec 31, 2008
    Same thing,there is a Red glow in the center of the screen especially when the picture is black i replaced the lamp and still the same thing can you help with a solution?
  • loopup Jan 30, 2009
    red haze on black background is exact problem I am having with Hitachi 50V500 model.
  • kbunday Mar 10, 2009
    Very large red haze in the center of the screen. Can see it even when the screen isn't dark and it is very disruptive to the quality and experience.
  • t_d_feledy Apr 11, 2009
    red haze over center 2/3 of screen also faint vertical lines over center 1/4 of screen
    Problem Solver:
  • 4 Answers
Problem is light engine---call to Hitachi got me the part free of charge after authorized repair service verified. I had to pay labor cost ($330) since unit (50v500) was out of warranty.
Posted on Mar 23, 2009
    Problem Solver:
  • 8 Answers
This problem is caused by a failure of the light optics engine, this is a very common problem on these TV's, I have replaced more than 35 of these in the last 3 years
The price of the part is around $500 to $650 not including labor
    Problem Solver:
  • 15 Answers
This is a convergance IC issue, not certain of the correct IC that needs replacement, but provided the unit is a tri CRT setup then I would assume that the IC that controls the fine tuning of the tubes is shot. More research is required, but upon replacement the unit will need to be reset to counter the offsets. ;o)
Posted on Dec 26, 2008
Have an LG LCD 42" flat screen probably 3-4 years
no there is no way, you have heated up the screen backing. only way is to remove the lcd screen and change it. as the screen its self is only 0.01 or 0.02mm at the most thick, you will probably smash the screen.
Oct 01, 2013 | Televison & Video
Blue Haze in middle of screen progressively getting larger
This one is easy. WHen this happened to me, I simply called GE extended warranty service up and bought an extended warranty. I waited 30 days and called them up with my problem. A repair man showed up a few days later with the 1200 dollar light engine and installed it and left. Then I called GE up and cancelled the warranty. Total cost?: 48 bucks
May 30, 2009 | Hitachi 50V720 Television
Blue smear on the middle of my screen
I just had the same problem with my Panasonic 52' A serviceman came and up date some info inside the set, took out the blue and red spots. it was covered under warrienty. TV is 3 yrs old. Try to call your local service center, that what I did. Hope this helps.
Apr 02, 2009 | Hitachi 60V500 60" Rear Projection...
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
LIGHT ENGINE FOR THE HITACHI 60V500
Hitachi WILL replace the part... My tv is over 4 years old and the light engine went bad. They sent me a new light engine free of charge two weeks ago and now it is PERFECT! When you call them make sure to ask for their superior if you get denied by someone.
Jul 10, 2008 | Hitachi 60V500 60" Rear Projection...
Dark picture, mostly red colors
if you set is over 4 yrs old the tube is at fault,you may try to adjust the screen settings.
Mar 27, 2008 | Zenith B25A76R 25" TV
TV REPAIR
John, bad news, short in picture tube, not cost effective to repair, even if it was the tube is no longer available for that age set, the bright side is it doesn`t owe you anything at 15-16 years old, too bad the "new tv`s" don`t last that long, hope this answers your question, BMW Rider
Dec 07, 2007 | Televison & Video
Having trouble with my Samsung television can you help please?
sorry silly girl seen this a hundred times!! The crt socket on the set needs to be carefully taken off and cleaned with wd-40 or tuner wash. its an intermittant connection on the screen contacts and the contacts that bias the grids.. It can be a green haze a blue haze or a red haze. Very common on 3 to 5 year old samsung tvs. Good Luck
May 08, 2006 | Samsung TXJ2879 28" TV
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
302 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
