Question about Kenmore 54602 / 54604 / 54609 Side by Side Refrigerator
Ice maker does not work
Bought in 2003 and stopped working at about the one year anniversary. Sears service says $600 to fix. Sears 54601
  • 302 Answers
I would go to a parts distributor for appliances and get one. Thats exactly what any appliance repair person would do, buy you an icemaker and charge you out the yinyang for labor to put it in. Very easy to do. Somebody at Sears dropped the ball by tellin you 600 bucks to replace when you can get the ice maker for less than 200 dollars.
Posted on Dec 06, 2008
  • 1,224 Answers
Is there any noise to it or did it just burn out
theres a couple things it could be iced up and all it requires is a thaw
also air in the line could make the icer not work properly
also you can do it your self i worked on them its one wire block 4 to 6 screws pull out have new ice maker ready put it back in ice makers are simple fix by selves cause its inside the fridge just remember to shut water off
your cost is just parts
The icemaker has stopped making ice and the reset function no longer works.
My name is Peter. I am a retired field service refrigeration technician.
Your ice maker has a control board, which I suspect is bad. This happens.
You did not provide a refrigerator model number which is located on a label on the inside liner wall of your fresh food section, so I do not know what you have.
I have a friend who called Sears Home Services for his ice maker. Sears charge him $440.00.
I have customer, same ice maker and problem. I charged him, $35.00 for the same ice maker and $30.00 to install.
Depending on the ice maker you may be able to install it yourself.
I need your refrigerator model number to help you.
Nov 30, 2015 | Refrigerators
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Older Kenmore side by side, freezer warm....again!
"Fuzzy Ice on the back wall" yep, this sounds like a defrost system problem. You say you cleaned this fuzzy ice but, the real ice is behind that wall. I would get it fixed but call several service people and get a price. My guess is that once the defrost system is working then the Ice maker will work. If the freezer is not getting cold enough then the Ice maker won't work.
Now, the drain can cause a problem too but this is an easy fix. Pull out the bottom drawer in the freezer, look in the back under the cooling coils and you should see the drain hole. Keep this area clear of Ice and any thing else. Some tubing with a little air pressure will usually clear any blockage. A little hot water down that drain won't hurt. The water should drain to the a plastic pan under the Ref. Take the front grate off at the bottom of the Ref, look in the pan to make sure it went through.
This should be checked often, once a month or so.
Dec 02, 2008 | Refrigerators
Ice maker LFX25960ST
3 months old?? warranteed for a year call for service , you bought new so you wouldnt have to fix it!
Oct 31, 2008 | LG LFX25960ST Stainless Steel French Door...
Kenmore bottom Freezer 795.75212402
there are many reasons why a ref stops working, you have not given any symptoms of what happened before it stopped working. The best solution is to call Sears and purchase a "service smart agreement" which will cover repairs up to $500 per repair for a year. there are other details to the agreement. the cost is about $240, but it's the best thing going.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE ice maker isn't working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Aug 08, 2008 | U-Line Refrigerator Ice Maker
Ice maker stopped working
I just had the same problem. You need to purchase a new motor module part numnber #8021515. I purchased mine at a Sears Service Center for 77.59. I installed it yesterday and again now have ice. Took about 10 mintutes to install. The tricky little part is removing the old one. Unscrew the three screws, and there is a white tab that needs to be pressed together (use tweezers) to remove the unit from the shut off arm.
Jul 31, 2008 | KitchenAid KSCS25FKSS Side by Side...
Ice Maker problem
Apparently lowering the temperature by 5 degrees in the freezer compartment will keep the input water tube from freezing. It is working fine now!
Nov 16, 2007 | KitchenAid KSCS25IN Side by Side...
Kenmore 54602 / 54604 / 54609 Side by Side Refrigerator Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
