Question about iRiver Audio Players & Recorders
Clicked the data refresh button but it wont come out this mode. It is stuck on system intialising there is a box with a circle with a clock arm going round and round
    Scholar:
  • 81 Answers
Hi, welcome to fixya,
your player cannot initialize because of multiple program running. some what a virus embed in your player, this happen when you download file from PC, using USB.
if you have a Updated or upgraded Anti virus it can help. or free AVG 8.0
Scan your PC (whole Computer) all files. if not scan by updated/upgraded anti virus.
and then please don't auto play your player when you plug it to your PC, thru USB.
at the My computer, right click the icon of your player and then, scan with your anti virus or AVG 8.0
after try to check if it is ok.
Posted on Dec 06, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would appear that your MP3 is in a loop or has failed to initialize successfully. Might you try to remove the battery (if possible) for a while and try again after an extended period of time.
Pls postback the exact model/version that you have.
Good luck and Thank you for using FixYa.
Mode safe start windows
In this case it would be best to perform a system restore.
There are two ways to perform system restore:
Open start menu click run and then type cmd to open command prompt.
Type CD.. to make c:\ only.
Type CD windows then CD System32 and then restore.
After once you find yourself in c:\ windows\system32\restore>
Then type restrui.exe press enter.
Once the system restore window open then click next to select any available restore point.
This process shall take couple of minutes to perform restore and please make sure that once this process started it wont be reversible and neither you will lose any personal data.
Other way to perform system restore is to open safe mode by clicking F8 on start-up and check safe mode option then further a dialogue box will open to ask for system restore and then follow the above steps. Thanks
Oct 27, 2013 | Computers & Internet
My Samsung monitor displays the message "Not optimum mode; recommended mode 1920x1080 60 hertz - Analog" - whenever I try to boot in a Safe Mode (WinXP). It works fine in a normal mode as well as in VGA...
  1. Navigate to the Control Panel in Microsoft Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
  2. In the Control Panel window, open Display.
    Note: Depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
  3. In the Display Properties window, click on the Settings tab.
  4. Toward the bottom of this window, click on the Advanced button.
  5. In the resulting window, which may or may not be tittled Plug and Play Monitor..., click on the Monitor tab.
  6. Locate the Screen refresh rate drop down box in the middle of the window. Under most circumstances, the best choice is the highest rate available. Depending on your issue though, the rate may need to be lowered.
    Note: It is always recommended to keep the Hide modes that this monitor cannot display checkbox checked. Choosing refresh rates outside this range could damage hardware.
  7. Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
Oct 13, 2013 | Computers & Internet
Wont load windows stuck in automatic repair
unplug, remove battery, leave battery out, plug in, reboot to Safe Mode, at reboot start tapping F-8 repeatedly until the menu comes up, select Safe Mode with Networking, in safe mode In Windows 7 type Run in the search box, in the Run box type msconfig, in System Configuration select Normal Startup, click apply and OK, close, click on restart.
Feb 27, 2013 | Asus Systems Asus S46CA Core i5...
My sony ereader prs t2 is stuck in demo mode how do I get it off
I found the answer at last. Despite instructions to fiddle around with the reset button and arcane combinations of buttons to press on start up, in my PRS-T2 the demo mode is controlled by a check box in the settings menu.
Touch "Applications" > "Settings" > "System Settings" >"Demo Mode" (turn the check box off) and you are done.
Dec 31, 2012 | Computers & Internet
I Just Formatted My System With Windows XP Service Pack 3 , My Displays Are Not Clear ,Its In Blur State.
If you mean the displays are kind of fuzzy at a partiuclar resolution, try changing the refresh rate. Whenever you install XP, refresh rates default to 60 Hz - this is rarely the optimum for the display. Most displays operate best from 70-75 Hz or possibly higher. Right click on the desktop, observe DISPLAY PROPERTIES window. Select the SETTINGS tab, highlight the display you wish to modify, then click the ADVANCED button. Select the MONITOR tab. Use the SCREEN REFRESH RATE pull-down to select the refresh rate you need. Be advised, if you select a rate the monitor cannot handle you will lose visual on the display and could damage the monitor. You can avoid this by selecting the "HIDE MODES THAT THIS MONITOR CANNOT DISPLAY: check box.
Jan 02, 2012 | Intel Computers & Internet
The black print on my Dell 1320C laser printer is very light (grey) in fact. I replaced the black toner at no avail. The other colors are fine.what can I do to soulve the problem. ...
It sound like you have either a very low toner density set, which would normally be set either through the control panel or the driver, or possibly the Dell Toner conservation system turned on. Here is Dells owners manual info on dealing with light print.
The toner cartridges may be low or need to be replaced. Confirm the amount of toner in each toner cartridge.
  1. Press [Printer Status], and then click the Status tab in the printer driver.
Ensure Non-Dell Toner is not selected in the Printer Maintenance tab in the Tool Box.
  1. Click the Tool Box button.
Set Toner Saving Mode to Off in the printer driver.
  1. Press [Printing Preferences], and then click the Advanced tab.
If you are printing on an uneven print surface, change the paper type setting in the printer driver. For example, change the plain paper to thick.
  1. Press [Printing Preferences], and then click the Paper Tray tab.
Verify that the correct print media is being used.
  1. See "Print Media Sizes and Support".
Ensure that eight yellow ribbons are correctly removed from the PHD (Print Head Device) unit.
  1. See "Replacing the PHD (Print Head Device) Unit" and "Installing the PHD Unit".
Ensure that the developer motor starts.
  1. Contact Dell.
Ensure that the dispense motor starts.
  1. Contact Dell.
When you are printing many images with low density, do the Toner Refresh Mode.
  2. Press the Start button to check the density of colors.
  3. If the print is too light, Select Refresh Mode from the list. Press the Start(1)-(4) buttons.
CAUTION: Using the Refresh Mode consumes extra toner.
  1. After you complete the Refresh Mode, select Chart Print from the list. Press the Print with A4(3) or Print with Letter(C) button for 4 Colors Configuration Chart. "Printing" appears.
    Is the problem recovered?
May 06, 2011 | Dell 1320c Laser Printer
Monitor flickers
Goes in the config panel, in display section, then the parameter tab, chose advance button.Then usually under the monitor tab, you'll find a refresh rate settings. Try 70hz setting. Also some time not using the protected ''power bar'' and connecting direct to wall helps alot. Let us know!
Oct 10, 2009 | IBM NetVista X41 PC Desktop
Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Oct 29, 2008 | LG Computers & Internet
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
19 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
