Question about KDS Valiant 6380iPTD-01 Notebook
I have a Vaillant boiler Turbo Max VUW GB 242/1E. Central heating works but no hot water
  • ritdav Feb 22, 2009
    the boiler is VCW GB 242 when calling for hot water boiler fires for a short period then goes off then back on .the mains pressure to the boiler is very good
  • 3 Answers
Diaphram leaking or poor electrical contacts in microswitch
Posted on Jan 06, 2009
2 Suggested Answers
gasman44
  • 83 Answers
SOURCE: I have a Vaillant boiler Turbo Max VUW 242/1E,
You have a faulty diverter valve, this is a fiddly job, you need to call in a 'Gas Safe' engineer to diagnose and replace this
I hope this helps
Steve
Posted on Jul 10, 2009
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
Vaillant turbomax vuw gb 282e hot water problem
Check for a control on the gas valve. Has this unit ever been hot? How long installed? Is it jetted for the right gas?
Dec 01, 2013 | Air Purifiers
I have a Vaillant ecoTech central heating boiler which has stopped working & is showing fault code F.76 Anyone know what this means please? Thanks
f76 over heat protection triggerd on heat ecxchanger , check water leval of just google vaillant fault codes
Jun 03, 2010 | Heating & Cooling
I need to power flash a vaillant boiler. can you please help. water goes hold and cold, sometime the heating stop but the water works and vice versa. i was told by an engineering that it needs power...
Hi
Although not a PC problem, i have had this same issue on my Vaillant Boiler, the problem you are describing is not a power flush problem, you need to clean out your exisiting diverter valve or purchase a new one
The diverter valve is repsonsible for either providing hot water or providing hot water to the central heating, when this valve gets stuck in between the symptoms you have described above occur
I would also not recommned that you do a power flush yourslef as you may end up damaging the boiler and its pump
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 23, 2010 | KDS Valiant 6380iPTD-01 Notebook
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
I have a Vaillant boiler Turbo Max VUW 242/1E, central heating is working but no hot water
I hope this helps
Steve
Jun 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler problem
check the air flow,venturi in fan and pressure switch
May 16, 2009 | Sun Time NCAA Purdue Boilermakers...
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
KDS Valiant 6380iPTD-01 Notebook Logo
501 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
