Question about Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive
Air leak i just bought a used a hitachi framing air nailer.it leaks air constantly from the trigger until i pull the trigger.also i dont even have to use the trigger.just press it aginst a stud and it shoots a nail.please help thats the first time ive used one and im learning it as i go.sorry the model number isnt on the gun or i would give that info.
    President:
  • Hitachi Master
  • 1,388 Answers
Several models of hitachi nailers share the same orings and other parts including the check ball under the trigger pin in your gun. Remove the roll pin holding the trigger to release the trigger pin, (plastic with one oring) then remove the valve with a screwdriver. Replace the vinyl check ball and seal. Parts are available at www.toolpartsdirect.com. This should fix the problem that you are describing, however use caution and check that the safety if properly adjusted. Enjoy
Posted on Dec 07, 2008
Hitachi 45ab blowing air out of trigger
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi framing gun leaks air from trigger when pulled
use the lube that came with the kit, you can replace everything correctly but if oring gets pinched it will still leak
Aug 14, 2012 | Hitachi NR90AE Full Round Head Framing...
DeWalt D51822 Framing Nailer: Replaced the trigger valve and air is still coming from the nose of the gun. I would think no air should get past the trigger valve until pressed. What's wrong?
Dewalt framing nailers use some vinyl orings (gold or clear in color) that fail too soon in both the trigger and the cylinder spacer. Air out the nose of gun indicates air is leaking past the cylinder spacer seals (If piston is pushed down with air leak then headvalve seal is leaking (remove nails for this test)). If piston is not pushed down with leak, remove head and pull out the cylinder with cylinder spacer (white plastic). Place the cylinder on workbench with bottom up. Push down on locking ring and remove retainer to release all the other parts. Take picture or take note of parts together and as you pull them off to aid in re-assembly. You will need to replace the two orings between the white cylinder spacer and the cylinder. Order oring kit from dewalt or just purchase one ( # 141 universal oring ) and one metric oring 74.4mm x 3.1mm from hydraulic parts store. If the piston was pushed down with air leak, replace headvalve orings in the head. Good luck with your repair
Jul 05, 2012 | Dewalt Heavy - Duty 31° Clipped Head...
My hitachi roofing gun leaks air from trigger when not pressed
Two areas to check when air leaks from around the trigger. Rubber ball under trigger pin will cause air to leak, however when good side of the ball falls on the seat, air will not leak for a while. If air is leaking from plunger pin (just in fromt of the trigger pin), remove the head and pull out the cylinder plate to reveal broken oring (oring part # 876161). Good luck with your repair project.
Jun 05, 2012 | Hitachi NV45AB2 Roofing Coil Nailer
Hitachi NR83 leaks from trigger
There are actually two trigger areas on this tool. There is the main trigger that uses an aluminum valve housing, plastic valve, a plastic ball, and most importantly a round, rubber seal under the ball. It is not an o-ring and often it gets bad which will cause the leak. Then there is a secondary trigger that the safety activates. Leaking air from there can be from a number of problems. Here is a diagram of your tool which will help you see what I am referring to.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/NR83A2_A2S_E2
Feb 27, 2012 | Nailers Hitachi Nr83a2 Flush Framing...
NRA833AA model. air is leaking out of trigger valve & will not fire. require manual to check operation.
Here is a link to hitachi web site listing for your gun. Look at the bottom of the page for pdf files of parts lists and manual.
http://www.hitachipowertools.com/store_item.php?iID=154&arrPath=1,9,43,p154,
There are two areas around trigger that can leak air. Spray soapy water on trigger stem and/or plunger valve. If leak is at trigger stem check vinyl ball. If leak is at plunger valve, most likely worn or broken oring inside of gun. Remove head and pull outer ring to reveal two orings. A worn outer oring will cause leak at plunger. If orings are ok on outer ring, pull cylinder and check for scratches where orings contact. If scratched, sand with 400 grit paper untill smooth and repack gun with oring kit. Good luck.
Jan 09, 2011 | Hitachi NR83AA3 3 1/4" Clipped Head...
Air leak
My Guess is that it needs a new "O " ring or some other form of seal some where round the trigger actuating spindle. Should be quite easy to fit if you can get one the right size
Jun 05, 2010 | Hitachi NR83A2S Framing Nailer, Full Head,...
I own a hitachi nr90ac3 framing nailer and i
Oil leaking out of the nailer anywhere is just an indication that too much oil is being introduced. A good solution would be to reduce the amount of drops until no more leaks out or use an in line oiler at the gun. An oiler costs under ten dollars and feeds in oil vapor as you use air. Store / hang your nailer with the air inlet down at night to drain out access oil. Do not worry too much about the leaking though, I think that a bit too much oil is better than a lack of oil. Good luck.
Apr 10, 2009 | Hitachi NR90AE Full Round Head Framing...
Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive Logo
287 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
bwbconstruct
Level 1 Expert
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
