Question about Holmes Products HOH2520-U Heater
My oil-filled Holmes heater HOH2520U will not heat now. it was working for a while the shut its self off and now the control panel is constantly blinking unless it is set at the room temp. HELP PLEASE
  • 4 more comments
  • Anonymous Dec 18, 2008
    Looks like you may have a fire hazard: the U.S. Consumer Product Safety Commission announced a recall; check out
    www.cpsc.gov/CPSCPUB/PREREL/PRHTML07/07168.html
  • Anonymous Jan 14, 2009
    i have the same problem with this heater although it's not on the recall list
  • Anonymous Jan 26, 2009
    I also have this exact same issue with a HOH2520 TG-U but it isn't on the recall list either.
  • 206pilot Mar 13, 2009
    Same blinking problem, unit shuts down. HOH2520 TG-U but production code not on recall list! ???
  • MWR2NY Mar 15, 2009
    Mine was blinking then shut down. My production code was on the recall list. I bookmarked this page and will return to it when I get a replacement unit.
  • Anonymous Mar 25, 2009
    I have the same problem.  Does any one know how to get a users manual?
I had the same problem. this is what i did. unplug the heater. removed the plastic panel to expose the control panel where the blinking light is.  Removed all the dust and cobweb build up, then using rubbing alcohol, wiped the white residue that was on the green circuit board. I did this 10 days ago and the heater has been working fine since then. chaz
Posted on Apr 04, 2009
I have two of these Holmes 2520 heaters, and strangely enough the one that shuts off and blinks is not under recall notice, and the one that works like a champ is. So I phoned Holmes and was told that ALL 2520 heaters are under recall. Phone them and send in your cord for a new heater!!!
Posted on Nov 03, 2009
Well...... lets see my heater almost burnt my house down it melted my wall plug n alson the wirers in the wall n also my wall too i would like for someone to contact me with a phone num to this company that makes these heaters an cause of this happing now the food in my frige now went bad caues didnt know that the wall plugs r connected an it blow that wall plug also so as you see im not a happy person an i would like for someone to contact me at (440) 536-5032 thank you so much
Posted on Jan 19, 2012
2 Suggested Answers
SOURCE: control panel blinking
Worked for me also. I had some coins down in the circuits too (4 year old). Working fine now, no more blinking.
Posted on Nov 30, 2009
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
I have a Holmes accutemp model HOH2520 TG-U. The heater operates for about 10-15 minutes and then the digital readout starts fluttering and it stops heating. The next day it does the same thing. Nice...
Hello- These heaters have been recalled.The Holmes heater company will mail you a new free heater, if u mail them back your power cord. Please check the recall website. Julie :)
Mar 02, 2011 | Holmes Products HOH2501 Oil Filled...
Will not turn on. Unit has been working great until tonight. Was on but now off and will not come on. Unpluged it for an hour but still not working.
This same thing happened to me, and yesterday as well no less. I've had mine for a 3-4 years. I think It had run out of oil, which is weird because I've had a Holmes heater for nearly 10 years and it still has plenty of oil left. If you shake it, can you hear the oil? I went and got another from Target last night (it was the coldest night of the year) and can hear the oil swishing around in it as I set it up. Hope it last longer than another 3-4 years or my next one will be a Holmes.
Jan 22, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Control panel blinking
my heater did the same, very frustrating. i have solved this problem.  i took off the plastic cover to expose the electronic circuit board and noticed that there was a white residue on the board. I wiped this clean with rubbing alcohol and put everything back. as of 3 weeks ago i have used the heater frequently as normal and not had any problems. chazdee
Dec 06, 2008 | Holmes Products HOH2520-U Heater
Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Jan 16, 2008 | Holmes Products HCT460-U Utility Heater
Not heating
Sounds like either the thermostat or the element. If you hear a clicking when you rotate the thermostat you can assume that it is working. My advise is to replacethe heater. The element is sealed inside the oil chamber and the thermostat will cost almost as much as a new heater, sorry.
Dec 05, 2007 | Holmes Products POH2501 Oil Filled...
Heater shut off but doesn't turn on by it'self
Do not touch the timer, once you do, it activates it. Set the temp. and leave the timer alone, unless you want it to shut off at a given time, 1 hr. and up. Once the timer shuts off you will have to start it manually.
Oct 14, 2007 | Honeywell HZ-709 Oil Filled Radiator...
Heater will not operate!
did you take it apart to see if the switch is good or the thermostat was functioning?  without looking inside, other than saying it don't work, isn't going to solve anything.
Oct 16, 2006 | Holmes Products HOLMES COMPACT OIL FILLED...
Holmes Products HOH2520-U Heater Logo
1,682 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
