Service list changed, keeps apearing and does not go away when ok or exit is pressed. this is a new hdb842, just set up
  • tonsil2000 Dec 23, 2008
    I have the same problem. Same model but I notice it only happens when I am on Channel 7. I wonder if their EPG information keeps updating - it seems to be about every 10 secs.
    Did you find the answer
Hi
this was posted on your website and I have just used it and it solved the problem.
Looks like TEAC will have a big return rate on this unit after Christmas!
Here is the solution again so that it is in more than one spot
Just download this firmware upgrade and follow the instructions
It's easy.
http://www.teac.com.au/pages/hdb842softwareupgradever161008
Tonsil
Posted on Dec 23, 2008
How can I reset my Philips 37 in flat screen TV back to the factory settings?
You haven't mentioned the model no. of your TV. Nonetheless, the reset procedure for the model nos. 42PFL7409/98 / 42PFL7409S/98 goes like this:
1- Press Home,
2- Select [Setup] > [Installation] > [Factory
settings],
3- Press play to enter the [Factory settings]
menu
[Reset] is highlighted,
4- Press OK to reset to default settings.
5- Press Home to exit.
The reset procedure may differ for other model nos.
Furthermore, Press the "Menu" button to access the menu, and select "TV Settings" and then "Picture" to bring up the picture settings. Adjust the color, brightness, sharpness and other settings if the picture seems off. Select "Dynamic Contrast" to have the contrast adjust to screen changes and "Digital Noise Reduction" to cut down on outside interference and reduce noise in the signal. On the "Installation" menu, select "Reset AV Settings" to have the settings reset to their factory defaults.
I hope the above helps.
Good luck.
Jan 11, 2011 | Philips Televison & Video
Do I need to retune my LE32R8 having difficulty
Yes.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Oct 01, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Samsung le26r74bd won't retune digital channels
Sep 30, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Trying to retune my samsung le19r8 in booklet itsays select set up then press enter button then again to select plug and play. on my set up menu plug and play is not highlighted cursor will not go there
Sep 30, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
How do i retune
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
Trying to change a fax number in memory
To change info:
"user tools" (ok)
"fax features" (ok)
"general settings /Adjust" (ok)
"program fax info" (ok)
...then set name, number, etc.
"user tools" to exit
To print speed dials:
"user tools " (ok)
"fax features" (ok)
"reports / lists" (ok)
"dial list" (ok)
"Quick dial list" or "speed dial list", etc (ok)
I hope I'm your Hero now :)
Please rate me.
Apr 01, 2009 | Ricoh Aficio 1013F Copier
Remote control for teac set top box HDB842 will not work .
I had the same problem and tried new batteries with no success until I had a close look at the terminals. One of the +ve terminals was rusted (Ithink a drink spill, hastilly wiped off). After restoring this terminal everything is now OK. Hope this helps.
Dec 26, 2008 | Televison & Video
Set top box - service list changed
yo, try this, i just bought the same STB and had the same problem. So far this has fixed it (fingers crossed).
cheers
Chris
Dec 17, 2008 | Televison & Video
Digivox DV3 cable box
You need to Enable the Emulator as this is what clears scrambled channels. Main Menu -Factory Settings enter code 1570 which should give you a new CAS menu. Go down to EMU and switch it on with >vol key. Go up to Negravision and select your area providerer and press OK. Exit and scroll down to Default and hit OK. Will flash "Saving". Exit all the way out.
With certain channels when you first switch to them they may take a minute to upload data automatically.
Good Luck.. Tom (Dublin)
If unsuccessful it is because the code above does not work on your Box. You will know straight away when you enter it if the CAS menu doesnt appear
Jul 08, 2008 | Televison & Video
HOW TO CHANGE WASTE INK ABSORBER?
I cannot find your model in the list but possbly one of these procedures might work. Worth a try?
http://www.fixyourownprinter.com/forums/inkjet/15284#532
Apr 20, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Televison & Video Logo
295 people viewed this question
Top Televison & Video Experts
Electro Med Services...
