Question about Acer Aspire™ T180 PC Desktop
Hello, i need to install additional ram to my acer desktop t180 and want to do it myself. I have heard about static electricity when opening pc but how can i do this to avoid it? I dont have the static wrist band thing.
Hi
got the same t180,changed upgraded my ram.
unplug the power,touch the computer frame with a metal rod,srew driver will do,as long as you also
touch the metal your self too.
did it to mine and works fine
this advice was given to me by Dell.
good luck
Posted on Dec 07, 2008
    Sergeant:
  • 302 Answers
Touch some wood or put some rubber gloves on. I wouldn't be too concerned about static electricity, just snap it into the slot correctly. If you have rubber soled shoes on, ur grounded..
Posted on Dec 06, 2008
My clock has to be reset each time i try to open email
Change the CMOS battery
It should be a CR2032.
FOLLOW Anti-Static Precautions.
The Positive ( + ) side ALWAYS goes up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 07, 2013 | Acer Aspire™ T180 PC Desktop
HELP! Acer T180 is possessed!
Have you Googled the beep codes? This is most likely your solution. You should do the RAM test on your system.
Blue Screen Of Death
  • Remove all USB attached devices.
  • You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM. Unplug PC. Opening case. Remove all RAM. Use static precautions!
  • Re-install Windows. Clean install works best. All data will be lost.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 04, 2012 | Acer Aspire T180 PC Desktop
I wanted to get my acer aspire T180-UA381B upgraded, and I know very little about computers, how much and what kind of ram should i put in to make it run fast
Based on your memory specs below the maximum RAM that you can install in your computer is 1GB
DDR2 SDRAM and you can get 1GB RAM for like $15 -$ 20. 1 GB DDR2 SDRAM is what you need to buy.
Your Memory Specs:
Installed Cache Memory: 256.0 KB
[close] Installed RAM: 512.0 MB RAM, or Random Access Memory, is the place in a computerwhere the operating system, application programs and data in current use arekept so that they can be quickly reached by the computer's processor. Theamount of RAM you have affects how quickly you will experience your computerworking.
[close] Installed Video Memory: 512.0 MB
[close] Max Supported RAM: 1.0 GB
[close] Number of Memory Slots: 4 x 240 Pin DIMMs
[close] RAM Technology: DDR2 SDRAM
Feb 11, 2011 | Acer ASPIRE T180-UA381B DESKTOP PC
I have memory problems on my ACER how do I fix it ?
I recommend to just replace the memory in the computer if you know for sure your having the issues with memory. That way no messing around and damaging any other part in the computer with the static from your skin.
Nov 19, 2010 | Acer Aspire™ T180 PC Desktop
Why do I have 2 hard drives (c & D)? Can they be combined into 1 (c)? Also I only have 1 gb of ram and I need more. Is it upgradable to 4 gb of ram? If so where can I buy the additional ram?
Yes...
But you have to reformat the harddrive and then install windows.
with a CD
You do a fdisk, rermove all drives, then make a new drive with no additions. Then you format it using thorough , not quick format
Jul 16, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
Acer t180 card reader problem not work yet! do i need driver?
The card reader is integrated with Windows Vista and XP so you will not need additional drivers.Make sure that your card reader is connected properly on your mainboard. At the back of you cardreader, there should be one thick black cable going onto the mainboard.
May 19, 2010 | Acer Aspire™ T180 PC Desktop
Best processor upgrade for my Acer T180
the processor you are using is the best combination for your computer and if you want to upgrade you should increase your RAM and install a good graphic card.
plz rate it .
Sep 13, 2009 | Acer Aspire™ T180 PC Desktop
When trying to boot acer aspire T180 computer only getting the acer screen and no response from the keyboard either help please help
Hello jamesruss590, this is material issues so first try to change your memory RAM and boot the pc again try this and answer me.
Jun 11, 2009 | Acer Aspire™ T180 PC Desktop
Upgrade possibillities for Acer Aspire T180
Specifications
Product
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
Processor
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
emory
256MB DDR2 533/667/800 SDRAM expandable to 4GB
1 Ok now that i found the spec for your computer here we go you can install the amd 64 x2 but not Phenom x4 9950
2 As for the graphic card you seem to know a little about computers so you can install and pci express x 16 graphics card that only needs one slot but remember some need power and this mean you my have to upgrade your power supply.So really you can by any single slot pci express graphics card for your computer so it comes down to how much you want to spend.
3.Ok for ram your max will be 4 gbs most likely ddr2 which mean that you have 4 ram spot in your computer.
hope this help please vote for me.
Oct 26, 2008 | Acer Aspire™ T180 PC Desktop
Installing memory
u sure it aint bad video card proably wrong ram type dual ch or no ? need help email me drummernick2002@aol.com live help thx nick
Jun 06, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
