Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
My canon digital ixus i the lens will not move when i turn it on.
My canon digital ixus i encounter a problem in the lens it will not open
thats why i cant take a picture
  • 1,550 Answers
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
  • Carefully inspect around it for dirt or debris
  • If you see any dirt or debris around the lens, use canned air to gently blow it away
  • After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Thanks for using FIxya
Posted on Dec 06, 2008
The camera is booting on ok but it does not show any response from half pressed autofocus. The lense does not move and neither does the photo, if it is blurry, it will remain so.
Canon PowerShot SD850 IS / IXUS 950 IS Digital Camera in this both models usually this problem appears, open the camera then take out the lens unit, below this unit you can see the iris control stepper motor and related small wheels this may be worn out or may be misplaced, correct it. if still problem,open the lens unit to check the possible break on the iris lens connecting cable.
Jan 28, 2016 | Canon PowerShot SD850 IS / IXUS 950 IS...
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
The lens is stuck open and when I turn the camera on it says lens error will shut down automaticlly restart camera
Try moving around the lens GENTLY. If does not help, call Canon, they will probably fix or replace it.
Aug 29, 2011 | Canon PowerShot SD1300 IS IXUS 105...
The problem is that the camera cannot open the front eye, when you turn on the camera it does not come out. and at the end it say lens error, restart camera, but still do the same thing. help cause i want...
Its a common error with cameras with retractable lenses. It could be a grain of sand stuck in the slide parts of the lens. Another cause is accidentally pressing the ON button when the camera is in its case.
The solution is usually "helping" the camera lens to come out. This is a tricky job because it requires putting pressure (by pulling) on sensitive lens parts. If you're not comfortable with that, ask someone else to have a look at it.
I've had one IXUS 860 which could not be recovered from the lens error. The second IXUS 860 had the same error - the lens however moved finally after turning the cap for a bit. In the first case it was sand. In the second had tried to push the lens out while in its case - the ON button was pressed.
Jul 04, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Canon Ixus 860 lens
If your lens comes out and retracs during power on or off then the spring that closes the lens is either broken or off trac. If you are within warranty period and able to open the case then it should be an easy fix. If not then you would have to get it repaired.
all the best.
May 05, 2009 | Canon IXUS 860 IS Digital Camera
Lens Opening Failure, Canon SD 950 IS
its a lens assembly problem, it might be damaged from impact or may be something like dust is making diffficult for it to work u have to take it ti service
Feb 20, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
