Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
You asked...Try to play a dvd on the tv and check if its coming in the full screen or does it have same results...Please let me know ...
Answer: Yes, we tried a DVD and it did the same thing. I also tried uplugging the TV for over 4 hours and nothing changed. Thanks for your help.
sandy beach
sandybeach on Dec 06, 2008
I have a sony 61HS10 rear projection tv.The small displays work, showing two or more pictures at the same timebut when you want to display just one large full screen picture thereis sound but no picture, It will also do a full screen freeze frame.Sound works fine. Color works fine, small displays are all workingwell, no blurriness. When you push button for one large picture and asmall picture in corner from another channel, the small picture worksand not the big one.
  • sandybeach Dec 09, 2008
    I got a service manual. It is hard to determine what the name (and or number) of the processors are that I should be looking at, do you have any idea? Do you know where I can get new parts? thank you
    Genius:
  • 2,035 Answers
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Posted on Dec 07, 2008
  • Anand Kumar
    Anand Kumar Dec 10, 2008
    Please use this link to get the parts :
    http://www.shopjimmy.com/TVs/Sony/Sony-T...
    Good luck...
Picture seems 3D an display showng duplicate
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board,must require changing it 2 STK convergence ICS and some or all it resistors too.These parts,must be change to solved the tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 13, 2010 | Sony KP-61HS10 61" Rear Projection...
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Jul 19, 2010 | Sony KP-61HS10 61" Rear Projection...
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Tv Problem
How many times does the light blink in between pauses? Also is your model the KP-61HS10 ? Please respond to this same post and I should be able to help you.
Jul 01, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
Feb 09, 2008 | Sony KP-61HS10 61" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
107 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
