Question about GE WBXR3100B Top Load Washer
Loud noise only during spin cycle and slight burning odor.
My actual model is the WCSE3100Aww, but this seems to be similiar. There is very loud noise that occurs only during the spin cycle. It almost sounds as if the basket and the tub are rubbing. Also, there is a slight burning odor that is evident toward the end of cycle. What might this be? Thanks.
  • 2 more comments
  • Darrell Cooley Feb 14, 2007
    Thanks for the reply Catriver. The noise is more like a loud zipping type noise (if that makes since). It even seems as if during the spin cycle the tub is spinning faster than normal; almost like it is going to take off. I will check your suggestions tonight.
  • erikarose75 Mar 04, 2008
    I have a GE Harmony WPGT9350C and have a similar problem. My wash machine starts and periodically throughout the washing it sounds like a loud zipping noise or like the start of a dirt bike. Occasionally I will have a slight burning odor as well, but not always. The noise can be very loud and concerns me quite a bit.
  • Anonymous May 17, 2008
    The spin cycle is very very load otherwise its ok and no odour comes from either. can anyone help?
  • Anonymous Jul 24, 2008
    When my washer spins or washes it makes a loud scrapping noise
    President:
  • 878 Answers
Cooleyd, is the sound like a chunk a chunk a chunk noise. If so, your motor is jogging between the high and low windings. the motor overheats and thus the burning smell. This is a common failure on these GE's. They came out with a motor kit with new harness and start cap. Remove the front panel by pushing on the 2 clips just below the top on each side. The panel will pull out. See if yours has the kit. It will have a start capacitor on the right side in front. On the motor harnes there will be a white and white/red wire. If you have a steady 120V during this jogging, you need the motor kit. Now with-out being there Im just trying to point you in the right direction. Other things to check would be the drain pump itself and whether there is something in between the tub and basket...Catriver..post back.
Posted on Feb 14, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
We have a whirlpool duet washing machine that is about 7 years old. During trhe spin cycle it makes a loud noise. Not the typical "airplane noise." There is also an odor. A burning engine odor. If you...
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
GE WBXR3100B Top Load Washer Logo
209 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
