Question about Coleman Heating & Cooling
I have a pm 1500 generator, it has not been strated for probably 3-5 years. I cleaned out the carb, put new gas with stabilizer in it and cleaned the existing plug. I tried to start it and it fired maybe three times and now I can't get it to fire at all. Please advise. Thanks
I had the same thing with the same generator a buddy of mine had. He said if I could get it running I could have it,,,well guess what, it's still running! :) I found that the pick-up jet inside the float bowl of the carburator was plugged. It's the jet that screws in to the side of the float bowl pick-up tube. Remove it, spray carb cleaner through it and the blow compressed air through it as well. I would actually do this with all the jets,,,as that is probably your problem.
Posted on Feb 17, 2009
I purchased the weedeater last year and it ran fine. This year I can only set the choke setting on #2. If I place the setting on #3 the motor will cut off. Please help. Thank you.
Its very important to drain fuel at end of season and use stabilizer but now the car will need to be cleaned you can do it yourself with carb cleaner that carb off and remove both covers spray real good hope it works if not new carb needed
May 03, 2015 | Garden
1500 not start
Did you leave any gas in it as it was being stored. If so then your probably looking at dirt or varnish in the carb. It this is the case you will need to taske the carb apart and spray the inside with some carb cleaner then make sure to wipe it all out. Next time you store your generator make sure that you compleatly drain all of the fuel. If not then be sure to add some gas stabilizer.
Good luck,
Marty
Jul 15, 2014 | Champion International Electrical Supplies
I have a coleman 6250 generator the carb bowl keeps flooding and it wont start a spring was at the bottom of bowl i have spark and fuel pressure
If it is B&S he spring is to hold up the plastic float housing to keep a tight seal to base of carb. Sits in the center of the bottom of the plastic piece and the bottom of the bowl.
Apr 10, 2011 | Coleman Powermate Premium Plus 6250W...
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel....
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Sep 02, 2010 | Electrical Supplies
I have a coleman 6250 generator, only runs when i spray fuel into the carb, it about a year old. With a B&S engine
Old gas has probably gummed up the works. You have to store these with an empty tank to avoid this in the future. Using a fuel stabilizer helps too. To fix it, remove all of the old gas. Make sure the fuel cutoff valve is open (it only turns 1/4 turn). If it has a fuel filter replace it. Put in just a little fresh gas in the tank with a bit of carb cleaner. If it still won't run, remove the carburetor bowl and you will see a donut shaped float that operates a valve. Using carb cleaner, clean that valve, and clean the needle valve in the middle of the bowl. Good luck.
Aug 09, 2010 | Coleman Powermate Powermate 5000W...
My 6250 generator has been dormant for a few years. Worked well previously. Can't start it now. It will fire with stater fluid, but stall. Fuel line checked and ok. I think Carb. might have buildup that...
yes gas will deteriate and leave varnish deposits clogging carberator and layer in tank has yellowish color flush lines with brake cleaner and spray carb with spray carb cleaner and spray inside fuel inlet on carb let sit about 15 minutes redo and sit about 4 times clean fuel tank with brake cleaner (with tank off) until clean, refill with fresh gas and add about table spoon carb cleaner per quart of gas and let in run for awhile. when storing for any period of time add fuel stabilizer to avoid this issue in future
Jul 07, 2009 | Coleman Powermate Premium Plus 6250W...
Generator won't start
i have the same problem. i took out the air filter and sprayed tb into it and it ran and died. this is the only way to get it to fire up.
i took off the carb, dissasembled it and blasted it out with tb cleaner, took out the jets too, put it all back and it still does the same thing. it is getting fuel but it won't run.
need a profesional answer on this one please.
thanks, tom.
Jun 13, 2009 | Yamaha 1,000 Watt Portable Generator...
I want to clean out my generator that has been sitting in my garage for almost 2 years, it has gas in it and it has been fired up only once since I bought it. Can anyone help.
First, I would drain out the old gas and put in freah and try it. If it doesn't start, try squirting gas into the carb and try again. Sometimes it will clear out the old gas a run. If not, the carb will have to be removed and throughly cleaned. The MOST important thing to remember about a generator, since they usually don't get used too often, is to ALWAYS keep FUEL STABILIZER in the gas.
Jun 07, 2009 | Electrical Supplies
My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Mar 29, 2009 | Electrical Supplies
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Mar 16, 2009 | Coleman Powermate Powermate 5000W...
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
