Question about Regal Ware K6725 Kitchen Pro Bread Maker
Shaft not turning
The shaft inside my breadmaker pan is not turning. When I turn the pan upside down, I see that one of the metal pegs is broken off. Can I just order that piece? Let me try to describe it a bit more. The shaft inside runs to the outside of the pan. On the outside, the shaft is surrounded by a metal piece that has two arms extending. The arms extend out on either side, or should, but one arm is broken off. There are two metal pieces inside the baking chamber to turn the two arms which turn my shaft. I thought maybe it would still work with the one arm, but it just makes a clicking noise, no action. But if I remove the pan, I can see those metal pieces in the baking chamber spin. They are working. How do I get this shaft spinning?
  • Anonymous Aug 02, 2008
    The drive shaft of my K6728CE breadmaker is not turning properly. I think the pan may have been immersed in water. Can I oil the turning mechanism under the shaft?
I realize this is over a year late, but I've just been searching for help with a similar problem. In my situation, the dough mix seeped through the rubber seal around the shaft in the bottom of the loaf pan. Gradually this hardened around the shaft inside the seal to the point where the shaft would no longer turn. I removed the external snap ring and eventually was able to remove the shaft and seal to clean out the hardened dough. In breadmaker's situation, this may be why the one of the arms or ears broke off of the drive gear. If another one can be made by a machine shop, it may also break if the shaft does not turn freely.
Posted on Jun 14, 2008
  • 944 Answers
Unfortunately Regal ware no longer supply spare parts for there breadmakers, because their motto about dedication obviously didn't apply to bread machines. I think youe best bet would be to take the pan and machine to a local machine shop and see if they could make you one up - if they could it shouldn't be too expensive. Hope this helps :)
Posted on Mar 24, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 24, 2007
    the metal piece that is
How do I get the bread out of pan, when the paddle will not release from the pan, and the paddle will not release the bread? I have to squish the bread completely and tear it from the pan. It will not...
did you flour and grease the inside, even if it teflon I grease and dust with a litte flour on some bread. if you turn it upside down and give it a few taps on the counter it works well.
Feb 01, 2015 | Kitchen Appliances - Others
Won't stay running. tries to run better if turned upside down. wont prime unless it's upside down
Fuel line is broken inside of tank. replace fuel lines and would recommend changing primer bulb as preventative maint
Aug 09, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I just bought a new B6000C bread maker. I have not used it yet. The instructions say "push the paddle down firmly onto the shaft to secure in place". But, my paddles just sit loosely on the...
No, there is nothing wrong with your bread maker. The paddle is supposed to be somewhat loose so you can remove it after baking for cleaning. Don't worry your paddle and breadmaker are fine.
Jul 26, 2011 | Black & Decker B2000 Bread Maker
I have this machine for 4 years now and I was happy with The central shaft does not turn now and I lost all my stuff... It makes the noise like if it works, but nothing happen... and there is a...
Hi.. The "central shaft" could mean the motor shaft is not turning or the "central shaft" could be the paddle shaft in the bread pan is not turning. If it's the motor shaft then tighten or replace belt. Since you "lost all your stuff" it could be the sealed bearing in the bottom of the bread pan has broken. The paddle doesn't turn and is leaking. If this is the case the bread pan needs replacement. Hank
Jan 18, 2011 | Black & Decker B1561 Bread Maker
Paddle shaft unable to rotate in the breadpan.
Hi, There is a sealed bearing in the base of the bread pan. When this sealed bearing fails the paddle gets stuck and will not turn. Take the pan out of the machine and see if you can turn the paddle by hand. If it doesn't turn freely, then it's probably the sealed bearing that is is failing. If it turns freely, then this is good news. Keep the pan out of the machine and go to a kneading cycle. Look through the lid window to see if the motor shaft is turning. If it is not turning, then a belt fell off , needs to be tightened, or has broken. Motor, belts and pulleys are in the base of the machine. Remember to unplug machine before working inside the machine. Finally, make sure the pan is seated in the machine correctly. Good luck Hankl
May 11, 2010 | Black & Decker Bread Machine
My breadmaker does not mix the ingredients when it is turned on.
1) Take the bread pan out of the machine and put the paddle in it. See if you can spin the paddle by hand. If you can...good. If you can't then the sealed bearing is frozen or broken. Try filling the pan with warm water and let it soak. If after a few times if you still can't move the paddle then the sealed bearing is broken requiring a new pan. 2) Keep the pan out and start a kneading cycle. Look trough the window on the lid. If the motor shaft does not turn then the belt fell off or has snapped. Good Luck..Hank
Dec 06, 2009 | Welbilt ABM3500 Bread Maker
Rotating shaft is jammed (won't move paddle)
Not quite sure what you mean about rotating shaft, but if you take the bread pan out of the machine and try to turn the paddle by hand and it doesn't move, then the sealed bearing in the bread pan is jammed or broken. Try filling it up with warm water and soaking it for a while. If it doesn't budge after a few tries then the bearing is broken and a new bread pan is needed. If on the other hand it does move, keep the pan out and start a kneading cycle. Look through the lid window and check to see if the motor shaft is turning. If not then the belt inside the machine is snapped, or fell off, or the motor is broken. Good Luck...Hank
Dec 01, 2009 | Black & Decker B2250 Bread Machine
Hitachi HB C103 bread machine pan seal
The problem isn't the seal, it is the bearing. You need to disassemble it, clean it, and lubricate it. Turn the pan upside down, and there's a C-ring that you need to pry off. Then you can tap the shaft through the bearing, and it will fall out. Clean the shaft and inside of the bearing, lubricate it, and reassemble.
I usually lubricate with vegetable oil, to avoid any chance of noxious contamination getting into the bread, but I've read a recommendation to use liquid graphite lock lubricant, available from NAPA Auto Parts, to prevent the bearing from sticking again as soon:
http://reviews.ebay.com/How-to-lubricate-your-bread-machine-pan-shaft-bearing_W0QQugidZ10000000016577277
BTW, be careful of that rubber seal -- they are apparently irreplaceable! (I need one, if you find a source.)
-Dave
http://www.burtonsys.com/email/
Oct 28, 2009 | Kitchen Appliances - Others
Shaft won't turn.
The bearing that lets your paddle turn freely has frozen up. The bearing is lubricated and sealed at the factory, but as time goes by it freezes up.
One person suggested to soak it overnight in soapy water (warm) and try turning it by hand. If you are lucky this may work, or if not, a new bread pan is necessary.
Hank
Aug 31, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
My breadmaker is not turning properly.
Try either turning the paddle slightly until it aligns with the "gear" under the bottom of the pan.
I've also pressed the start button, and when the mixing process began, managed to push the pan down until it's engaged properly.
Apr 16, 2008 | Sunbeam 5833 ExpressBake Bread Maker
Kitchen Appliances - Others Logo
212 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Irene Tulloch
Marvin
Marvin
Ruth summersides
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
