Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
V6211au not booting up (no display)
I am a computer engineer
i have compaq presario v6211au it is showning blank screen. it give led on but laptop is not getting on and their is no display.
it is not under warrenty now
i need to understand how to techcal althis problem and how to reset the laptop and how to reset hardwarely
how to make bios defualt hardwarely
and what can i cheak on mother board to slove the problem
as i am a engineer i uses to do laptop repairing up to curtain level
please guide me to do it so
  • Anonymous Jan 16, 2009
    Hi, I am Sony from delhi, Unfortunatly we both are on the same page. i tried calling HP and after a loads of research i found that its an known hardware issue with Compaq V6000 series and also with some other models of HP. and HP is also providing free technical support to these know issues. please follow the given link for more information : http://h10025.www1.hp.com/ewfrf/wc/docum... . and check whether your laptop is under these given scheme. you can also try Power drain step - unplugg the Ac power, take out the battery and press the power button for 30-40secs and plug everything back. it worked for me i hope it would work for you also. please revert to SonyA@hcl.in if you found any other alternative. Thanks & Regards, Sony
  • modz_brinka Apr 24, 2009
    i am a computer engineer
    Sergeant:
  • 302 Answers
I think your motherboard is gone
Posted on Dec 06, 2008
Compaq Presario v4000 will not boot screen stays blank
Overheated chipset/VPU. It needs resoldering.
Oct 09, 2014 | Compaq Presario Notebook
HP Compaq Presario V3000 PC Notebook - Screen Blank, Won't Boot
try to put the windows installer, and re-install again your OS.. format the drive and install a fresh copy of windoes..
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario CQ56-115DX shows a blank screen on boot, but runs perfect on external display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2012 | Compaq Presario CQ56-115DX Laptop
Hi i have a compaq presario laptop and after it stars up the screen just goes blank
do you still see the compaq logo and does it show you the windows boot up screen before it goes blank?
OR
do you see anything on the screen at all after pressing the power button?
Check if the laptop is receiving power. If it has power and you can't see anything on the screen it could mean that the LCD assembly or the Video card of your laptop is bad.
If it goes to the compaq screen and then to windows logo before going out, try booting into safe mode and once there uninstall the video driver from the device manager because that means the resolution was set to something higher than the display could handle.
If it restarts after showing the compaq screen try reseating the memory, hard drive and wireless card of your computer put them one by one and try turning the compter on after each part you put back to check which component is point of failure.
Otherwise you have a bad motherboard and it may have to be replaced.
Hope this helps!
Jul 27, 2011 | Compaq Presario 700 470024-192 Notebook
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
I have compaq presario v3000 laptop which is having on board NVidia graphics, actually the problem is when i power it on, the power LED, Volume LED are always ON. there is no display on the screen its...
Based on your statement its like the laptop is booting normally but there is no display. Common problem on HP is their poor design on cooling system. In your case I would say the video card has reach its full extent. But you may want to observe this:
  • If it has a dedicated video it probably have a secondary fan for it, check if its rotating, if not then it caused the video to overheat.
Unless you know how to tore apart your laptop, you will not be able to further check this. Better send it to a service center.
Feb 24, 2011 | Compaq Computers & Internet
I have a compaq presario v6211au with amd turion processor i hv purchase it in 2007 , after purchasing it gave me many problems like battry, adapter, but one problem still coming about its oipening...
the screens is dead right, no BIOS screens at all, means.? what?
power problems
main battery out , run now
coin cell dead? 2.9v and above is good.
power pack bad, 19vdc ok , is it.
power jack at the MOBO edge bad, as all do.?
see this?
https://www.amazon.com/Presario-V6210us-V6211AU-V6211TU-Compatible/dp/B009WWBWFY
Jul 17, 2017 | HP Compaq Presario V6000 Motherboard -...
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
Compaq v6211au starts but black screen. Two continous beeps.
If u r familiar to open panel of ram in ur base of the lap then open the panel of the ram at the base and remove the ram there might be dust cavited on the ram just clean the ram and reinsert into the ram slot ur lap starts working.
Hope this solution will help u in this regards...
Jul 13, 2009 | Compaq Presario Notebook
Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
Nov 26, 2008 | HP Compaq Presario v3000z Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
177 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
