Question about RCA D52W19 52" Rear Projection Television
RCA 52" will power on but shuts down immediatley
2 weeks ago I moved my TV, the same day i couldn't get a picture. Finally the picture came on. All of a sudden when I went to turn my TV on today the green light appears and then shuts down.
Plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Posted on Mar 01, 2007
SOURCE:
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
NO PICTURE COMES ON THEN SHUTS OFF
there is no vedio on the input are the tuner.
Oct 13, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W119 Projection tv
You have 3 capacitors on deflection board ,ck them cp150,cp111 cp114.cp150 2200uf 15v green/gold writing.
Oct 13, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 - turns on and off, blue screen, tech said need picture tube
It does sound like the tube, have the shop use a tube restoration machine to rejuvinate the tube, and replace the eprom to try to correct the no power down situation.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
148 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
