Question about Whirlpool Duet GHW9150P Front Load Washer
Wash cycle water level
I bought my duet as a floor model without a manual so I don't know how much water the wash cycle is supposed to have. it seems to barely have enough to wet the clothes. my house has low water pressure so I wonder if thats part if the problem. if I use the manual rinse cycle it seems to have enough water. I know these machines work differently and I haven't sat and watched an entire wash cycle so I don't know if the water increases later in the cycle.
    Genius:
  • 1,224 Answers
The water needed needs to just come up right under the door this is how much water they use cause they use a tumble wash to clean the clothes
low water preasure is a problem but also make sure both water inlets are being used (hot and cold) even if you dont have hot attach a y hose the machine needs both inlets in use
these machines use very low water usage but they still need a fill up point
Posted on Dec 06, 2008
I bought a brand new Hotpoint washer, model #HSWP1000M3WW. The water level for super size load during wash seems high enough. But the water level for the rinse is about a third of the super wash level. ...
I would check with the vendor that sold you the unit and see what they have to say or send an email to the Contact Us link on their website and ask. I am guessing no mention of the in your owners manual?
Dec 03, 2014 | Washing Machines
I want to increse the water level on my whirlpool duet WFW9750WW01 front loader washing machine. Plese help
I've read your owners manual online and found nothing on changing the water level-I did read that there is a procedure to add an extra rinse cycle to the each washing-here is the link to the owners manual http://www.productsmanual.com/read/whirlpool-pdf-wfw9750ww01-duet-automatic-washer-owner-s-manual.html-cheers Denny
Oct 21, 2013 | Washing Machines
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I dont seem to get enough water to wash
your washer is domestic,it census how much water should be in there,the laundry mats are commercial washers that cost anyware from $10,000 to $20,000 each they are build to handle a lot more
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On spin cycle water leaks from under the washer all over the floor
First thing is to make sure the washer is level and balanced, use the screws on the bottom and a level. Once level run and see if leaks. Also move closer if possible to the place the water drains to(or is supposed to drain to). If there is know leveling screws check manual to get part number to order, but first check other solutions as not to waste cash on screws you don't need.
Jan 31, 2010 | GE WBSR3140DW Top Load Washer
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Long cycles on my whirlpool duet washer
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
159 people viewed this question
Dan Webster
Dan Webster
Sal De
