Question about SanDisk Sansa e250 MP3 Player
Sansa e250 my thing froze and when i turn it on it wont get past the refreshing database screen what should i do
  • 5 more comments
  • big swede Nov 23, 2007
    after loading music and disconnecting from the computer i turn on the e250
    sansa and refresh database appears and the bar makes it about half the way across the screen and then the screen goes white.
  • jermonster Mar 06, 2008
    I had the same problem but another is that what is the file to be downloaded because the link you have given is not complete. can you give me the complete link to it. you can email me at jeremy_c_perater@yahoo.com.ph. my firmware version is old since i have not updated it after i bought my player. thanks
  • laughes Mar 06, 2008
    How do I reformat my Sansa mp3 player?
    I can't switch it on, because it does this weird restarting thing and the menu will not come up at all.
    It shows the SanDisk logo and then the whole screen just goes white, and it does it over and over again.
    I know someone else had the same trouble... but I don't know how to reformat it :(
    how can this be done?
    how can i format it in recovery mode?
  • laughes Mar 08, 2008
    Version Info: Product Rev.: PP5022AF-05.51-S301-01.01-S301.0.1.47-D
    Base Code: 05.51-S301-01.01-S301.0.1.47-D
    ODM Ver.: S301-01.01-S301.0.1.47-D
    OEM Ver.: S301.0.1.47-D
    Build Type: -D
    Build Date: 2006.10.07
    Build Number: (Build 169.31) \
    "load image failed"
    switch to recovery mode
    can anyone help me with my sansa e 250
    i have also given my version details
    please reply me at smiles_kartik@yahoo.com!!! please do reply
    thank u in advance
  • mj2387 Mar 09, 2008
    My database will not refresh
  • Anonymous Feb 13, 2009
    i have the sam porblem
  • Anonymous Feb 16, 2009
    freezes constintaly doesnt work
I have had the same issue with my Sansa when putting some media types on it. I have had to install the firmware again. It is a slight pain, but your player will work again. I'll post some steps from a crash solution to fix it. 1. Switch the player's hold button on. Hold down the record button and power up at the same time. This will bring you into recovery mode. Now plug your player into the computer. 2. Go to http://www.sandisk.com/assets/file/downl... and download that program. Run the program and select yes to format and install the new firmware. 3. Unplug the player and wait for it to reset. This will install the old firmware version, so once it is working again, go to the sandisk site again and download the updater for the firmware and install that. These are the simple steps to a firmware fix, and should take care of the problem. -JJ ...let me know if there are issues with this. There is another way to install the firmware if this one doesn't work.
Posted on Feb 14, 2007
This is not a sollution, but a comment about your solution JJ.. i had the same problem with my mp3 and i tried doing what you said, and i got to step #3 and when i turned it on to refresh database (followed by selecting MSC mode or whatever) it got stuck again in the same spot its been in for a month.. im sure it has something to do with the music i downloaded, i dont know, but its very aggrevating to not be able to USE my mp3 player! thank you for posting this solution, i hope you have another idea about fixing my problem.. thank you- Talia
Posted on Mar 26, 2007
SOURCE:
My Sansa e200 will turn on, thumbwheel is blue and SanDisk screen comes on, but menu won't come on. I have pressed and held the power/menu button down for app. 15 seconds several times to no avail. It is...
sandisk sansa e250 starts but then says refresh database. Menu is in back ground. Maybe frozen, and have tried to reset, but still come up with Refresh database.
Sep 27, 2009 | SanDisk Sansa e250 MP3 Player
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa screen turns black after "refreshing database"
how about updating the firmware?
OOOOHHHHH
now we are getting somewhere
( how could someone not figure that out.... ha ha ha)
Dec 20, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 screen is stuck on refresh database
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked! M.P.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
My sansa froze
Try to remove the battery and force the machine to switch itself off
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa E250 Froze..
that happened to me once. all i had to do is hold down the power button for at least 15 seconds sometimes more. if not call tech support
Jan 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
296 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
