Question about LifeView FlyVideo 2000 / FM (701013821030) Video Capture
Cannot render audio capture stream
Hi, I just recently bought a Fly Video 2000 FM TV turner card and for some reason I can't record any sound, but I can with video, when I try to do so on LifeView TVR Version 3.21.400. I get an error "Cannot render audio capture stream" as soon as I try to record something.
I tried everything to enabling the line-in on my settings in Windows XP, and tried playing around with a whole bunch of other settings on the Lifeview TVR too. I've also noticed when you go to the audio settings in Lifeview TVR, there is a field called Recording Control, but its always left blank.. Above it is Audio Input Source, and I can change it to anything accordingly, but Recording Control doesn't give me anything to select.. I'm not sure if that has anything to do with my problem overall.. ?
  • 8 more comments
  • Anonymous Dec 26, 2008
    Exactly the same as described above. Anyone found the solution yet?
    Yes, I have the same problem as above. Please can someone tell us the way to fix this problem with the audio?
  • Anonymous Dec 27, 2008
    I have the same problem. It's got to do (probably) with Realtek 888 audio not having a separate slider for recording line in. I have found no solution yet. Maybe one should tweak the setting files.
  • Anonymous Dec 31, 2008
    Yes the same problem... i've tried everything.. but nothing... please someone help us!!!
  • Master Lucka Jan 11, 2009
    yep. me too
  • Anonymous Jan 22, 2009
    I have the same problem , I think it is a compatability issue between my TV Tunner Card (Lifeview TV Prime 30) and the Audio of my motherboard (Realtek)
    I didn't find a solution yet but I have a seprate sound card from my old PC I think I will install it and use its line in in the recoding from the TV tunner card if I couldn't find a solution soon
  • malakamn Feb 17, 2009
  • ahmedishere Feb 23, 2009
    I have the same problem on my life view card
  • lionofgod57 May 06, 2009
    its already may.6.2009! has anybody found a solution yet? pls post ASAP. or ill have 2 change brand!
  • alsbban46 May 19, 2009
Sorry for my english, i have 2 mother board Gygabyte, one with Realtek chip ALC888B, the other with Realtek ALC850.
The card Life view fly tv prime 30, work ok in record video e audio with l' ALC850 and do not work (yes video no audio) with ALC888B.
  • The ALC 888B probably is the newest chip of Realtek. I have resolved disable by bios the ALC888B, disable also AZALIA codec, also by RISORSE DEL COMPUTER-GESTIONE PERIFERICHE-CONTROLLER AUDIO VIDEO E GIOCHI -REALTEK-UTILIZZO PERIFERICA -NON utilizzare questa periferica (disabled). Shut down the pc , and i have installed an hold audio card sound blaster live 16 (PCI slot). After reboot and installed driver (forgotten: i use xp sys op.) After this life wiew card work perfectly also on this mother board. This is my solution, i understand the is not simple naither cheap.
Posted on Jun 28, 2010
  • 3 Answers
On the "Audio Settings" in the Life View software, at the "Audio Input Source" on the drop down arrow, select "None". This settings will use the internal PCI Bus for listening and recording TV. The audio loop back cable in this case is not needed anymore.
Posted on Sep 05, 2009
This would seem to be the design of sound cards on current motherboards. I don't know how they can get away with selling them, as they make many tasks impossible. My TV card had the same problem, as did Audacity. I fitted a sound card, but lose a PCI space on the board. The firm I bought the board from refuses to show my review, and Realtek have yet to reply to emails.
Posted on Feb 23, 2009
If on XP, go to control panel, sound and audio devices property, go to the Audio tab, select the default device, recording device, note these should be the same device, I.e the mother boards sound card not any other virtual mother board. now go to the voice tab, change voice playback and voice recording to the default device. apply and exit. open the audio setting of the TVR, recording control should be line in. now u can record.
mungai.lawrie@gmail.com
kenya
Posted on Sep 02, 2011
2 Suggested Answers
  • 1738 Answers
SOURCE: Hi, I just recently bought a Fly Video 2000 FM TV
This is a free dvd decoder program that you need for your audio. http://files.uberdownloads.com/apps/lps/index.php?product=vlc
This will do simple files, but it is more complex file it might take a software like nero 8.
Posted on Nov 23, 2009
I recently purchased a Philips SAA7130 tv turner card and installed evrything but they is no sound coming out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} An [5003:0x8004ase8] has occurred running the setup
Jul 25, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Pixel view pro3 SAA7130 TV Tuner/FM Radio/Video PCI Capture card after installings it says adding video tee smart failed what will be the reason for this problems
Pixel view pro3 SAA7130 TV Tuner/FM Radio/Video PCI Capture card after installings it says cannot render video capture pin to null filter plz help me
Jun 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Tv-tunner cannot render audio capture stream
What cable connections are you using? HDMI has to be enabled on you motherboard (high def. audio), if its S-Vidio you must run a seperate and dedicated audio cable from headphone jack to TV.
My first gues would be to right click your audio icon on your desktop toolbar and check your playback and recording settings, make sure the tuner card is the source, hope this helps!
Apr 03, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
IBOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO...
BOUGHT MY PHILIPS SAA7130 TV TURNER/FM RADIO THE MANUAL STATES THAT I MUST INSERT THE CD KEY FOR THE FIRST TIME WHEN ISTALING BUT I DIDNOT SEE THE OPTION WHEN INSTALLED MY CARD AND IT SAYS FM RADIO OPTIONAL BUT NOTHING IS PLAYING FROM RADIO
Mar 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
WHEN I RECORD,IT SHOWS A 'NO AUDIO DEVICE
driver for ur video capture is not ok...Win7 lite version has not included all drivers....
if it works with XP then keep that rather use win7
Dec 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
HOW T DO I CONECT A VHS VIDEO RECORDER TO MY WINFAST TV 2000XP EXPET TV CAPTURE CARD ?
Your VHS recorder has a Coaxe output! So does your card the sound will be replicated there as well, now it would not hurt to get a capture card that has those plugs as you rendering would be much more prestine. Pluag you VHS into the coaxe input on your card set the channel to 3 and you got it bud!!!
Rulds2008
May 25, 2009 | Leadtek WinFast TV 2000 XP Expert...
I cand recording the sound
can u hear sound ,,and if not you need to download the sound drivers to hear sound and to record sound and you can download it from this website
sound drivers ---> http://www.softwarepatch.com/utilities/ac97.html and http://www.softwarepatch.com/utilities/ac97.html
Jan 16, 2009 | LifeView Fly Video 3000 (701013821560)...
?Error? Cannot render audio capture stream
Download intervideo windvr and your problems are over!
Feb 18, 2008 | Philips TV Tuner Video Capture PCI Card -...
LifeView FlyVideo 2000 / FM (701013821030) Video Capture Logo
5,024 people viewed this question
Top LifeView Televison & Video Experts
Rommel Balcita
Tony
Dominic
Dominic
Are you a LifeView Televison and Video Expert? Answer questions, earn points and help others
