I want to disable end proccess option fora particular procces on my machine through VC++ code
    Novelist:
  • 171 Answers
Depends, do you want it to "exit gracefully", or forcibly shut it down immediately?
To exit gracefully, you use the ExitProcess winapi call. To -kill it immediately, use TerminateProcess winapi call.
For both calls you need the process handler which may be obtained by walking the existing processes on the system
here's an example of just using exitprocess / terminateprocess
http://promo.bigpond.com/homenetwork/html_new.php
here's a more in depth example that actually walks the process list so you can kill the process by "name" instead of by process id:
http://www.physiology.wisc.edu/ravi/software/killproc/
Posted on Dec 06, 2008
Can i wire 1 channel to each voice coil on my **** with 2 cables?
Not recommended, if you have a 2 Ohm DVC this will give you a result of 4 ohms, You are better off Wiring AMP (-) to (-) on one VC then another wire from (+) on same VC to (-) on other VC and then (+) on other VC to (+) on AMP, this will get you the same result. You run a high risk of burning the Voice Coils if you wire up the way you speak of.
Mar 11, 2012 | Power Acoustik MOFO-12 Car Subwoofer
How to solve when its hang
When a program on your PC is hanging, simply press these combinations simultaneously:
CTR ALT DEL.
If you are using XP, this should automatically open up the taskmanager. But if you are using Vista or Windows 7, it would open up some options, from which you are to choose to start the task manager.
There, you would see the list of running programs and non responsive programs.
End the programs that are not responding.
If they proove difficult to end, then go to processes, and end the proccess which the progam runs on.
Hope that Helped?
Success.
May 24, 2011 | Samsung Galaxy Tab Tablet PC
Remte code number Vc-H-800
I also haver a Sharp VC-H810 and need the remote code.
Jan 09, 2011 | Sharp VC-H810U VHS VCR
KM-1820 machine reports "waste toner
You need to replace the procces unit. The waste toner can not be emptyed the unit needs to be replaced, Some times if you remove the proccess unit and gentally shake it left to right several times and place the unit back in the copier the error will clear, if not you will need to replace the process unit which is a PU-102.
Jan 07, 2011 | Kyocera Office Equipment & Supplies
Can't find the code
Code 7 is the display module.internal proccessing error.It can be the main module but more likely to be the display module.
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Which are the differents diagrams to wire two sub dvc 4 ohms
I guess this Amp is stable down to 2 ohms. 500 Watts X 1. Unfortunately there is no way possible for you to present a 2 ohm load to the output of this amplifier. Here are your options.
Speakers in series with VC in parallel = 4 ohm total Z
Speakers in parallel with VC in parallel = 1 ohm total Z (not good)
Speakers in parallel with VC in series = 4 ohm total Z ( Whats the point)
Speakers in series with VC in series = 16 ohm total Z ( Whats the Point)
So your best option to maximize power transfer from your amp to your speakers would be option 1. (Z = Impedance)
Dec 13, 2009 | Kenwood KAC-8104D Car Audio Amplifier
I have trouble taping when i put the timer on it does't tape.
You are looking for a user manual? Is the Sharp VC-A554U VHS VCR the correct model or do you have another device?
Thank you.
Jan 26, 2009 | Sharp VC-A554U VHS VCR
Decodeing UPC-A Supplemental 2 or 5 code
you should have a code book that came with the scanner, the code book allows you to program the scanner's options, the code book takes you step by step through the programming proccess. each option requires you to scan varios barcodes to "set" the various options one of the options will be to set the barcodes you wish to use, this is set to avoid a misread (confusion between barcode standards)
Aug 07, 2007 | Symbol LS 4000i Handheld
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
