Question about Microsoft Office Professional 2007 Full Version for PC
Delete a virus and back folder inside USB
How to delete a virus? because my folder is all deleted,and how to back my folder?because all inside my folder is all projects,pls how to back in my usb.
    Genius:
  • 1,224 Answers
Goto safemode run virus scanner this should get rid of viruses since viruses have nothing to attach too
if you have vista safemode is tricky to get too somtimes it works sometimes it doesnt
also in safemode you can back up your files with out viruses
recommendation get a big external hard drive and start storing files you want to keep to that so when a virus hits you just un plug and go straight for a virus kill
Posted on Dec 06, 2008
All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want...
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
May 24, 2011 | Computers & Internet
Tip
How to avoid getting virus in your flash drives or pen drives?
Well virus normally gets in your flash drives (pen drives) by putting it to an infected computer... this happens most of the times & you bring those virus home making your life miserable...
Some anti-virus deletes all your infected folders as soon as you put it into the USB (thus deleting all your important files inside them)
What to do?
Before you know this, just take note that those virus attack your folders mainly in 99% cases.
The trick is to either not put anything in folders in your flash drives OR if you put them into folders, compress the folder by programs such as 7-ZIP, Winrar, Winzip etc
You'll see that your documents will be safer!
Please send your votes & feedback to motivate us!
on Feb 18, 2010 | Computers & Internet
I CANT DELETE FOLDERS IN MY HDD
Download a program called "Unlocker" and use that to see whether your folders are locked, and this will let you unlock them so you can delete them :)
http://download.cnet.com/Unlocker/3000-2248_4-10493998.html
Mar 08, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
How to remove autorun.inf, system volume information, recycler etc virus from the harddisk.
1st: Go to Tools>Folder Options>View>unckeck this items below:
1>display the contets of system folders
2>hide extensions for known file types
3>hide protected operating system files(Recomended)
2nd:check all other options in VIEW
3rd:APPLY>OK.
4th:Download unlocker 1.87 ,install it after that enter any drive (C:,D:,........) and delete the recycler folder >then a error message will appar and shows that " can not delete RECYCLER:access is denied." it's in use.>click "OK">after that the "unlocker 1.87" will appears automatically and will give options "noaction","delete","rename","move" at down-left corner and there you can select " delete" optinon by scrolling down and after that you can success fully delete the virus,RECYCLER,from that drive.:D
continue this proccess for all drives where you can see RYCLER folder
NOTE ADDED: This site is listed by McAfee Site Advisor as a potential source of adware and malware.
another answer::::::::::::::::::::::::
Use a batch file (Example.bat) to change it from to a non hidden and a non read only file. It will convert it to a deletable folder and delete it. Do not delete the Autorun file because I found that the virus changed one of my documents to the autorun.
@Echo off
ATTRIB -S -A -H -R
Pause
Then if no errors come up after running the batch right click on RECYCLER folder and click delete.
Make sure the Batch is in the drive not the subdirectry.
(Example) - DriveLeter>Example.bat
Hope this helps : )
Please note that the following advice if taken will absolve me from any responsibility. I am only reporting what I did to get rid of the virus installed on my hard drive.
1. You should be able to see your root drive root drive which is c: or d: etc.
2. Ensure that you are able to see hidden files by going to Tool>Folder Option>view and checking off hidden files.
3. System Volume Information and Recycler should be visible in your root drive (c: d: or whatever drive you use)
4. Right Click on Recycler folder and go to Properties.
5. Go to the tab labeled Security, If your user name is not there then add your username that you use for XP . Give yourself all security rights as well as the SYSTEM user. Then press okay. If you cannot see the security tab and you are using XP professional then go to Tool>Folder Option>View uncheck box "Use simple File sharing" then select Apply.
6. Right Click on System volume information folder and go to Properties. Repeat step 5.
7. Go to the garbage icon on the desktop and right click. Choose properties then check the box " Do not move files to the recycle bin. Remove files immediately when deleted." Press Apply.
8. Go back to the root drive and delete Recycler folder.
9. Go to the System Information folder and delete the last folder. These folders are where Xp has taken a snapshot of your system in order to restore it. The virus is hiding here in the event that you restore it is also restored.
10. You should now open the registry editor and remove the virus from here so that when you restart the virus is not recreated.
11. Open the registry editor. Start >Run> then type regedit in the box and select OK The registry will now open.
12. Hit Ctrl+F Type Recycler in the search box . Delete the entry when found. press F3 to find the next occurrance of Recycler and delete.
13. Close regedit.
14. Go to all installed harddrives and so steps 2- steps 6, steps 8 and steps 9.
15. Run your virus software. You should be able to update any virus software that was previously unupdatable.
16. Reboot your computer
17. Verify that that the reycler folder is deleted from you root drive.
18. Then you can uncheck the box in the garbage that you checked in step 7. To keep all you deleted files in case you need to restore a file that was accidentally deleted.
My findings: This virus is recreated using the methods of the garbage bin. Everytime you delete a file it recreates itself because it looks in the garbage and restores or copies the virus information inside. If the virus is not able to be stored inside and is immediately removed when you check the box in step 7. Then it cannot recreate itself and all of its power is lost. So erasing it from the registry and drive ensures that it cannot return.
I frequently get this headache and finally heartache sooo annoying it had brought too much trouble for me. After installing various kinds of software, running them and so on, I found some of them useful and some of them not at all effective.
Even if we make changes in folder options to view all the files and change various settings, searching through regedit etc or following by some software, in most conditions a typical average user lands in confusion and finally some disaster happens to his system.
I found this simple system to effectively remove Recycler virus - Blam to Recycler virus.
1. Go to Desktop, right click on Recycle bin and select properties.
2. Check (select or put a tick mark) on the square box (Do not move files to the recycle bin. Remove files immediately when deleted)
3. Get File zilla FTP which is free and install. (you dont need to change any file settings)
4. without entering any sort of web address anywhere click the directories in the Local site box.
5. Then each directory will display all the folders below this box with file name, file size, file type and last modified.
6. Now check if RECYCLER folder is there. Then simply delete it.
7. Your job is done.
8. Repeat in all the folders by searching if it is sub folders too.
9. Repeat for each directory ( C D E F ...)
After your job is done again go to desktop, right click on recycle bin and then deselect on the square box.
Apr 21, 2010 | HP Computers & Internet
How do I delete or repair the threat to my Laptop system that has
HOW TO REMOVE RAILA ODINGA VIRUS IN 2 MINUTES
How to remove raila odinga virus is a very easy process. Firstly, Raila odinga is a worm that attacks Microsoft word files, but it looks like a JPG file and mostly found on the desktop.
Raila odinga has some common characteristics
1. If you delete the picture file it will delete and return to where it was.
2. It runs from the driver folder in system 32 folder
3. it auto runs at system startup
4. It makes the computer boot slowly
5. It makes your computer to hang.
6. It creates new folder.exe folders in your computer
How to remove raila odinga virus, open my computer, double click drive C: open WINDOWS folder, double click on system 32 folder, open driver folder,
locate the word file in the folder, note the name. Right click on the task bar, open task manager, click on the process tab locate the name of the word file you saw in the drive folder, right click on the name of the file, click end process, to terminate the running process
Open the driver folder of system 32 where the file is, delete all the ms word files on that folder, then close the folder locate the raila odinga picture file usually on the desktop or somewhere in your computer, delete the picture file. Please do not double click on the picture file only delete it, finally empty your recycle bin and restart your computer. That way odinga is off your machine.
Mar 25, 2010 | Computers & Internet
Why would all my pictures disappear if i never deleted them.?
if you r sure that u havnt deleted then check if they are hidden or not, a virus can also affect the pics so beware of the virus!!!!! to check the hidden files click folder option then ckeckmark show hidden files and folder then apply and check ur pics.
Oct 16, 2009 | SanDisk 2GB microSD Memory Card
About Virus
Delete using Antivirus it can be surely deleted my recommendation is kaspersky antivirus or internet security
Jun 19, 2009 | Altec Lansing ADA995 Speaker
Downloaded Frostwire to a memory stick, can't delete folder.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 19, 2009 | PNY 2GB microSD Memory Card
Usb flash drive icon changes into folder icon
This issue may have resulted from a virus infection on the machine the drive was plugged into.
You’ll need to delete the file autoruns.inf located on your flash drive.
By default, Windows hides this file, so before you can delete it you must make a couple of changes (you may reverse these after you’ve finished):
Open My Computer
Tools
Folder Options…
Click on the View tab
Under “Hidden files and folder” choose “Show hidden files and folders”
Remove the tick from “Hide protected operating system files (Recommended)
OK
Go back to My Computer and click on your flash drive. If you can’t open it that way, try right clicking on it and choose “Explore.”
Find the autoruns.inf file, right click on it and choose “Delete.” Confirm “Yes.”
Unplug and re-plug the drive in. You should be back to normal.
Hope that helps.
Feb 26, 2009 | LG KU250 Cellular Phone
Scandisk cruzer - system files deleted
Hi ,
You can Uninstall the U3 system , link to uninstaller can be found at : http://www.u3.com/support/default.aspx#CQ3
once you uninstall it you can go back and reinstall the U3 system from the same website.
Jan 29, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Microsoft Office Professional 2007 Full Version for PC Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
