Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
My Carrier furnace started making a very loud whirring noise. I shut it off, and after the burners went off, the noise went away (the blower was still going). I waited a few minutes and turned it back on. Once the burners started going, the loud noise came back but was intermittent. My dad listened over the phone and thought it was a belt slipping?? Any ideas? I'd appreciate any help as it's cold tonight and it's not possible to turn back on due to the nosie!!
  • 1 more comment
  • Anonymous Feb 07, 2009
    me too same problem
  • SheriAP Mar 02, 2009
    Before I could figure out where the noise was coming from, I thought an 18 wheeler was parked out front back firing. When I went to the front door, there were no trucks, so I realized it was upstairs in my attic. It woke my whole family up at 5 Am. My husband turned it off and we've called a repairman. We also smelled a burning smell, not gas, not electrical...Like the first time you turn on the heater for the first time during the fall.
  • dwkcool May 11, 2010
    First turn the fan to the on position ckeck for noise if not there turn back to auto and turn unit on and see if it is the combustion motor making the noise
I had this same problem. I changed the filters and now it's quiet.
Posted on Feb 01, 2011
  • 29 Answers
My weathermaker started making a screeching noise and intermittantly would shut down, without blowing any heat. I found the sediment trap clogged and the induction motor was churning through the backed up condensation water. This slowed the motor down and the pressure switch would not stay closed. Unclogging the trap and hoses solved the problem. A bunch of water came out when I disconnected the collector box drain hose, along with gobs of sticky crud. Works great and is quiet now.
Posted on Jan 13, 2009
My furnace makes a loud noise on start up
What kindof sound? Is it a squelling kind of sound?
Jan 03, 2013 | Heating & Cooling
Toshiba Portege r200 is making whirring noises
Its problem two things. One, the fan on the heat sink or your hard drive. More than likely your hard drive.
Feb 06, 2010 | Toshiba Portege R200 Notebook
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Turning on the heat makes a loud noise then i turn it off and just run the fan no noise
This sounds like an oil burner, which would mean your getting an oil biuld up in the fire chamber when the burner fires up. If it is a gas furnace you need to ajust the air flow.
Oct 03, 2008 | Carrier Heating & Cooling
Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
4,491 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
