Question about Kitchen Ranges
Kenmore gas oven temp not accurate. Could be high, can be low.
The range is in a rental. The renters say they set the temp. at 375 degrees and may reach that temperature and stay for 30 minutes or so and then it may go up to 450. (They are looking at a thermometer they have placed inside). Sometimes the temperature may be down into the 200's or even go off but the readout still indicates that the oven is at 375 degrees. Sometimes the oven may work ok. I was told also they could hear it clicking inside the oven sometimes like it is trying to light and control the temperature but may not be lit.
    Habit-Forming:
  • 171 Answers
The oven themperature needs to be calibrated, the set screw it's in side of the oven knob when you remove it in the senter of the shaft there is a very small screw, turn it , beon that replace the thermostat.
Posted on Dec 06, 2008
I have a Kenmore Elite oven. The upper oven doesn't maintain temp setting. Eg, if I set baking temp at 375, oven may get to that temp but a few minutes later, it's at 325 or less. Broiler works fine.
im taking that it,s gas....do you smell gas at anytime? sounds like you migh have a light gas leak if it,s gas...also how old is this oven?
Aug 13, 2016 | Kenmore Ovens
I have a Chambers majesty double gas oven that needs new thermostats and clock is not working. I would be happy even if its a universal thermostat
Get any and all numbers you can find from the original controls. Also make a note as to the length of dial shafts, direction they turn, shaft size and "flat" location when in off position and the temperature range and whether high to low or low to high.
Then go to this site and search for exact or something that you could live with. . . . http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19145&pID=18668&mode=categorysearch . Hope this helps!!
Jul 31, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Sep 30, 2009 | Kenmore Kitchen Ranges
Oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Aug 09, 2009 | Kitchen Ranges
Temp on oven is not correct
Good Evening.
I would make sure that the conversion kit was the correct kit for your stove. Also, if it is not heating properly I would call the gas company and tell them the conversion did not work and they need to double check their work (at no charge). If everything is in order proceed to the next step below.
You can try removing the Oven Temp control. There is an adjustment on the knob which will vary the temp + or - 75 degrees F or so.
Procedure: Preheat your oven for 350 degrees F. Give it a good 1/2 hour to 45 minutes and then pull the knob off (usually held on with a set screw) You will need a thermometer that will go up to 500 degrees (I use an electronic one but you can use any kind as long as it is within the ovens temp range. If the oven is underheating simply turn the oven control stem to a higher setting, say a 50 degree incrament. Wait another 1/2 hour and measure temp inside oven. Keep in mind when you open the oven door it affects recovery time, etc so 30 minutes between a measurement and adjustment should suffice. Once you have adjusted the temp control to your target temp of 350 degrees look on the back of the knob and see if there is a stop adjustment. There is a chance the temp control knob could be setup differently but the same philiosphy/procedure will be similar.- the adjustment could be on the stem itself instead of the knob.
Also keep in mind that the oven temp will fluctuate from high to low as it tries to adjust to the temp it is set at. That is why it is very important to give the oven time to cycle low to high when you incrament the temp control. Hope this helps and good luck! Gary
Mar 14, 2009 | Whirlpool SF325 Gas Kitchen Range
Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
the oven safty valve is goin bad. that the part that most oven burners sits on.
Dec 09, 2008 | Amana ARGS7650SS Gas Kitchen Range
Low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Oct 17, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
197 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
