Question about Jandy AQUALINK RS TELELINK KIT
Water level whent to low and know wont heat water
Pump still works
  • 125 Answers
Link to the users guide and owners manual
Posted on Mar 04, 2009
Coolant level on 2006 Toyota Avensis Tourer 2.2 T180, Very Low within two weeks of being topped up?
have a pressure test done on the cooling system and find the leak
it could be in the radiator tanks , timing cover behind the water pump, water pump seal, head gasket, cracked head or welsh plug rusted out
check the sump oil condition and if it is grey that is where the water is going
Nov 14, 2015 | 2006 Toyota Avensis 2.2
Coolant level keeps getting very low?
Check the upper intake gasket, you may have a leaking gasket. Check the bottom of water pump and see if it is leaking, if so pump needs replaced. The seal within the water pump sometimes goes bad and leaks out seep hole on water pump bottom. Make these checks with engine off!!! God-Bless!
Nov 14, 2015 | Cars & Trucks
I have a chevy equinox that was over heating and would leak coolent took it to the garage they said it was a water pump and the thermostats they changed them and flushed the tank. Not a week latee it over...
I suspect there was an air pocket in the cooling system, sounds like the garage didn't bleed the system completely, just keep an eye on the coolant level, if it remains constant I would suggest your problem has been resolved. But don't forget, only remove coolant cap when engine is cold. Regards Mike
Oct 28, 2013 | 2005 Chevrolet Equinox
I have replace the thermastat and water pump and the heat still is not working properly
what anti freeze did you put in it and what level is it at if its low it will do that and if there isnt enough water with antifreeze it wont warm up enough
Dec 05, 2010 | 1995 Lincoln Mark VIII
I noticed that my the spa water level got really low. My pool pump is has stopped working. The breaker was tripped and I reset and it tripped again. Is the pump fried?
Probably the heater. Turn the heat off and try it. There should be a flow switch to prove pump is on before the heater works, but sometimes if you're running low, it will work intermittent. Do you know how it got low? evaporation? Is the pump leaking? If the pump is leaking, and has leaked for awhile it may have shorted out the motor. While running the pump low on water will damage the mechanical seal that keeps the water in the pump, it should not affect the motor itself.
Oct 19, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Won't blow out heat while sitting still, but will generate heat while riding along
Most likely causes of this is either low coolant level or a plugged heater core, of which, I'd lean towards the low coolant. Rarer causes would be a slipping drive belt for your water pump, or a dying water pump.
Check the coolant level in the coolant bottle and top off with a 50/50 mixture of antifreeze and water if it is low. There should be markings on the side of the bottle to let you know the proper level; markings for both a cold engine and a hot engine.
If the level is low, you might want to have the vehicle checked to make sure that there isn't a leak somewhere.
Jan 07, 2010 | 2003 Chrysler Town & Country
Car over heats,fans are working can't find relay.
low coolant level , restriction, bad water pump, or stuck thermostat.
Jul 19, 2009 | Ford Escort Cars & Trucks
My car is over heating
Hi
debbie, It could be as simple as the coolant is too low. When the car is cold (not driven for 4 hours or more) check the level in the overflow bottle, it has a level (usually cold and hot), fill to that level., and also take off the radiator cap. The radiator should be filled up to the bottom of the cap. Fill that too. (your car owners manual will show the locations of this, or ask someone who knows abut cars)You should be using a 50/50 (half water half antifreeze)mix of water and antifreeze (coolant).You can also purchase it already mixed at any parts store. When the level is too low, your heater won't work, and your car will overheat, so it's possible it wasn't refilled all the way after the water pump was replaced. Let me know if you have any questions, and how you make out w/ the car. countrycurt0
Aug 16, 2008 | 1999 Saturn SL
Whirlpool TUD6700 doesn't drain final water load.
if your pump or something is not working it wont drain, but if only the final drain wont complete its most likely normal
if the water level is just below the heating element then im sure its normal, because that is normal for whirlpool dishwashing brands, its due to long hoses or height of hoses, also low water pressure
if not id go with a timer/pcb
Apr 29, 2008 | Dishwashers
Jandy AQUALINK RS TELELINK KIT  Logo
138 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
