Question about Jandy AQUALINK RS TELELINK KIT
The spapool water whent to low and switched of and wont heat up
The pump still works just no heat
  • 125 Answers
Spapool pump
First things first. When ever you fill your spa put the hose into where the filter goes, if it's a top load filter. Or into the skimmer if your spa has one. That way as it fills it forces more air out of the lines as it fills and limits how much air gets trapped in the lines. That being said, turn the power off, you can't bleed the pump if its running. On most pumps there is a bleed plug threaded into the face plate of the wet end. Loosen the plug until you hear air coming out. Once the pump fills with water and water is coming out of the plug, tighten it up and turn the spa on. I t may take several try's before you get rid of all the air in the lines.
Nov 08, 2013 | Pool & Spa
I have a chevy equinox that was over heating and would leak coolent took it to the garage they said it was a water pump and the thermostats they changed them and flushed the tank. Not a week latee it over...
I suspect there was an air pocket in the cooling system, sounds like the garage didn't bleed the system completely, just keep an eye on the coolant level, if it remains constant I would suggest your problem has been resolved. But don't forget, only remove coolant cap when engine is cold. Regards Mike
Oct 28, 2013 | 2005 Chevrolet Equinox
I noticed that my the spa water level got really low. My pool pump is has stopped working. The breaker was tripped and I reset and it tripped again. Is the pump fried?
Probably the heater. Turn the heat off and try it. There should be a flow switch to prove pump is on before the heater works, but sometimes if you're running low, it will work intermittent. Do you know how it got low? evaporation? Is the pump leaking? If the pump is leaking, and has leaked for awhile it may have shorted out the motor. While running the pump low on water will damage the mechanical seal that keeps the water in the pump, it should not affect the motor itself.
Oct 19, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
This is an early model livia 90 (~1994). Problem is no heating of water. Pump works but neither heating light or pump light comes on. I determined the power relay was not closing. Replaced it with new...
Hi
I would check the level probes on top of the boiler. There is a yellow wire going to the high level( left) and a green wire going to the low (right) probe. The probes get scaled and do not sense water. If there is no sensing of the right probe ( low water) it will not heat. They both need to be cleaned. There is a nut or a big nut that will allow for the removal. Clean both probes and it should go back to normal.
Dec 26, 2009 | Pasquini Livia 90 Espresso Machine
Filter Pump motor is On, but no Water Circulations.
You have probably pulled the center out of the impeller. Please shut this pump off immediately before you over heat and distort the housing and damage the motor.
You use a paper filter on this device? This has salt water in the tub? or you use salt water as a water treatment?
I think you had your spa running and you turned it off for some reason and immediately turned it back on. If there was ANY pressure in your system, that pressure was running the impeller backwards when you turned the motor back on and that is why the center is pulled out of it.
Of course there may be other reasons for this problem and you will never get anyone to admit to doing this ... but it was evidently done.
I frequently find this problem at work where I maintain three public bodies of water ... till I got rid of the 'pool attendant', that is!
thanks for posting your question at FixYa.com
If you find this response helpful, please vote
thanks
Dec 21, 2009 | Washing Machines
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Espresso maker wont heat up
Hello. This sounds like you have a low water condition, or the heater has failed, it is hard to say without knowing more. However, here is a link to the service manual area at Bunn, of discontinued units. Take a look, see if you can provide more information concerning the problem, after looking at the manual, and you may want to consider having it checked by a service company that works on these all the time. If you have a lot of scale in your water, something could be clogged or stuck. Maybe the fill solenoid is not opening, clogged filter, etc..
http://www.bunnomatic.com/pages/techdocs/manuals/dis_man_index.html
Hope that helped, and thank you.
Mar 28, 2009 | Bunn NHB Coffee Maker
Jandy AQUALINK RS TELELINK KIT  Logo
142 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
