Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Old thermostat wiring doesnt match up with new thermostat
My old wiring was as follows: G, C, R, Y, O, W2 (with jumper to E) My new thermostat is a Honeywell RTH7600 and I have no clue how to wire this. I wired it the way that I though it would go, but the heat comes on when the a/c is supposed to be on and vice versa. I'm assuming that a couple of wires are backwards, but I dont know which ones.
  • 2 more comments
  • kdlucas Dec 06, 2008
    This T-stat is fully digital. So there are setting in which I can change for different systems such as heat pump w A/C, heat only, A/C only, etc. I have changed them, but the heat is still coming on when the air should be. I am more concerned with the original wiring not being the same for this T-stat versus the old one. On the new one there is a section labeled "Heat Pump" and one labeled "Conventional." If I use the heat pump labeling, then there is one wire left, W2. the W2 area on the T-stat is under Conventional.
    It is all electric. I have an air handler inside and one outside unit. It is a heat pump
    The wiring is just like the old T-stat except that the old one had the white wire going to W2 and E.
    Old wiring:
    Orange - O
    Green - G
    Blue - C
    Red - R
    Yellow - Y
    White - W2 & E
    Orange - 0
    New wiring:
    Same, except that the diagram on the plate has an outer list of terminals and an inner list. The outer is "Heat Pump" and the inner is "Conventional" I have it wired on the heat pump list, but there is not a W2 on the heat pump list so i have the W2 wired on the conventional list.
  • kdlucas Dec 07, 2008
    I changed a few of the digital setting, being that this thing is totally digital. It seems to be fine and will blow cold and hot when supposed to. I left the white on the W2 side with a jumper to the E as it was on the old T-Stat. I appreciate all of the help and for being so quick.
    Thank you.
  • 334 Answers
Look at the instuction booklet (or on the T-stat board) for a switch for the reversing valve.
Some systems reversing valves are in cooling mode when energised, some are in cooling mode when NOT energised.
You are looking for the switch (Usually very tiny, or a different jumper setting) that will change the position of the reversing valve when calling for heat/AC.
This is not a switch like the typical "ON OFF AUTO, HEAT COOL EMG HT switches. It will be on the board itself or the back of the T-stat.
Posted on Dec 06, 2008
  • Danny Clark
    Danny Clark Dec 06, 2008
    Do you have a heat pump or a gas furnace? Is it an electric furnace?
    What wire is left over, what wires are you currently using on what terminals?
  • Danny Clark
    Ahhh thats your problem, disconnect the white from the conventional side and let me know what terminals are on the HP side.
  • 4 Answers
After you selected function 170 and set it to 7, your next function to set is 190( this is for your heat pump changeover valve) If you wired "O" to your O/B terminal, set 190 to 0, then press DONE. This should correct the problem.
Posted on May 05, 2009
W and W2 wiring on old thermostat...where do they go on the new thermostat?
It depends on the equipment you are connecting the thermostat to. If you have a heat pump, the thermostat must be wired differently than if you have separate heating and cooling equipment. If you have a two-stage or modulating furnace (or boiler), the w and w2 wires will conect for heating, and the y and g wires will connect to the air conditioner. Naturally, some configuring must be done with the new thermostat so that it acts correctly. w-w2-wiring-old-thermostat-go-new-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
please mark this answer helpful.
Feb 22, 2013 | Honeywell RTH6400D 5-1-1-Day Programmable...
I have old Honeywell with 7 wires W2, L, B, G, R, Y and E. Now I have bought Hunter 44155c with six terminals: G, RC, RH, Y/O, W/B and Y1. How can I connect them? Thank you so much for your help!
You need a 2 heat, 1 cool, heat-pump thermostat. W2 is the heat from the heat-pump unit outside, E is the emergency heat inside the house (usually electric), and on the new thermostat you just have the one W terminal for heat. You can jumper the two wires together (W2 and E from the old thermostat), but you will get both heats all the time when its being called for. Since you may have powered heating instead of powered cooling, I would try to get a thermostat that matches up better, otherwise, you might run into more problems than just the terminals, like rewiring the heat pump and furnace/air handler to accommodate the new thermostat. Hope this helps, and if you still have problems afterward, be sure to explain which wires were already hooked up to which terminals and so forth so we can have a little better idea whats going on, sometimes it can get confusing without being there. Good luck and hope everything works out for you!
Jun 19, 2011 | Heating & Cooling
I have an old Bryant heat pump. I got a Hunter 44860 2 stage heat/2 stage cool but I am having problems with the wires. These is the Bryant set up (the wire colors do not match)...
This should help you. You need to know if your thermostat is powered by the unit or independently and which way your reversing valve switches (I,m not sure on a Bryant, but probably Your old O wire goes to your new O terminal. They should pretty much match up, the new stat just has more options. Thermostat wiring
Jun 09, 2017 | Hunter Fan Company 5/1/1 Programmable...
The Honeywell LR69071 (old) has 7 wires connected labeled (X W2 R O Y G E) The Hunter 44860 (new) has wire connections for ( Y1 Y2 W2 G RH RC/R B W1 E O C L) What connects with what? There is also a jumper...
Wiring on the old one, "X", probably a brown wire will not be used on the new stat. If it's a blue wire, this may be your common. "E" and "W2" probably wired together with a white wire, this controls electric heat. "R" with a red wire, this is 24 volt power. "O" is an orange wire, this is the reversing valve. "Y" is a yellow wire, this is the contactor. "G" is a green wire, this is the blower. This pretty accurate? On the new stat, the jumper should be connecting "RH" to "RC/R", leave it in and wire the "R" from your old one to either terminal. White from the old one will go to the "E" of the new one. If your electric heat doesn't work after the install, you may need to jumper the "W1" and "W2" with the "E". "O" wires to "O". "Y" from the old one wires to the "Y1" of the new. "G" wires to "G". "C" on the new one is common. Usually a blue wire goes here. If "X" on the old one was blue, plug it into the "C". If it was brown, I'd suggest not using a common, and installing batteries. Hope this helps.
May 03, 2010 | Hunter Fan Company 7-day programmable...
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
I had an old thermostat that i had to change need wiring diagram
both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
Dec 20, 2008 | Honeywell Programmable Thermostat Heater
Thermostat Wiring: W2? E? Where to connect?
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
Dec 15, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
3,621 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
