Question about Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick pro duo won't record pictures
My camera is saying there are no files in the folder and that there is no memory space in memory stick. however, i've deleted all the pictures from it so i can have room and it still wont let me take more pictures. it's basically saying the memory card is full when its not. help!
  • kswehla Dec 06, 2008
    thank you so much! i'm terrible with these kind of things!
    Genius:
  • 1,224 Answers
Stick in computer and reformat the memory stick but dont let comp add anything to it
Posted on Dec 06, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
Apr 26, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
I have pictures on the memory stick pro duo 2GB card that show up on my camera but when i insert the card into the computer it says that there are no folders. i know the pictures aren't just in the...
Once it was happened to me, I went in folder options, enabled 'show hidden folder and files' option and got all pictures in memory stick that were hidden in picture folder for some reason. Selected all with CTRL+A, right clicked, clicked propertise and uncheck hidden mark
Try that, might help you.
Nov 08, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
My computer can't read pictures from memory stick pro duo
there or to picture folders on the psp one is in the root of the memory stick and the other you have to open the memory stick then open the folder called PSP
Aug 04, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Getting my pictures back onto my camara
Connect camera with computer with USB cord, power up camera, computer will recognize it and if you installed Sony image mixer software that will prompted, close it, click My Computer, click removable Disk, click folder to open it, now you can copy pictures from computer and paste here but be careful about picture file name should be DSCxxxxx some thing, if you have already changed file names then camera will not show these picture in playback mode though pictures would be on memory stick.
Apr 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Error Viewing pix
Do not use a Memory Stick Pro Duo - High Speed , use a Memory Stick Pro Duo below 2 GB
Apr 16, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Memory Stick Pro Duo says it's full when not - photos to iMac
move the auto install file then reformat the flash drive as fat.
Apr 06, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
Memory stick
the 101 is the folder number the pics are stored in-what model sony is it?-are you sure the camera is not recording to the internal memory which may be full-did you try to format memory card or reset the camera to factory defaults?-if none of these work may be bad camera-are you using a memory stick pro or pro duo card?
May 21, 2008 | Cameras
How to clear my memory stick
This camera has both internal memory and allows use of Memory Stick Duo type cards. To format Memory Stick Duo, choose "Memory Stick Tool" and then "Format" from main camera menu, hit "Ok". Choose "Create REC Folder", hit "Ok".
Apr 26, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony 2GB Memory Stick PRO Duo Memory Card Logo
125 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
