Question about Frigidaire Washing Machines
How do you remove and replace Frigidaire washer model FWT645RGS1 timer knob assembly?
I requested instructions from someone who didn't charge for the information. But thanks for following up!
Posted on Dec 06, 2008
How do you replace the timer on a frigidaire frontload washer
Good Morning Friend,
I understand you are trying to replace the timer on your Frigidaire Affinity washer, model# ATF7000E. If it is just the selector knob you are replacing, you should only have to snap the new knob on. If it is anything other than the selector knob, typically it is not a do it yourself repair. I do suggest contacting your local authorized technician for further assistance. They have been trained on your specific appliance, and will be able to better assist, and replace the timer on your washer. Hope this is helpful.
-Best Regards-
May 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front loading washer model FWT449GFS1
For a repair manual, contact Frigidaire directly.
Oct 07, 2017 | Washing Machines
How can I remove the timer knob from a Frigidaire Washer
Knob PN 131592001 Just looking at replacements it appears to just push on. If pulling on it does not get it off then rotate it CCW in an attempt to unscrew it. Just be VERY careful that the timer stem does not rotate if you turn the knob CCW or you will be buying a new timer. Open the top and hold the stem if you have too. (easier said than done) Worst case... if you have a bad knob and have a replacement knob in hand... break the defective knob. If your changing the timer look at the stem on the new timer. If it is threaded on the end the knob unscrews. If it is not threaded it pulls off.
May 11, 2011 | Frigidaire FWS833A Top Load Washer
Need directions on replacing the knob-Timer Assembly for the WSXH208V1WW. Bought the replacement part but can't find any instructions for removing and replacing it.
Remove top of washer then Remove timer knob then (2) screws behind knob, un- plug timer connector and replace of course always unplug machine First
Sep 27, 2010 | GE WSXH208A Front Load Washer
I have a Frigidaire gas dryer. First, the timer
check the ignitor element those go bad after long usage... if you see that when you turn the machine on and the ignitor turn red but the flame not start then you need to replace it.
let me know if it help you , if not let me know as well we will keep working on it...
Jan 12, 2010 | Frigidaire ATF6000ES Front Load Washer
How to replace the selector control knob on a Frigidaire front load washer Model FWT449GFS2
Push-in center knob and and turn Counter Clockwise to loose it from the treaded shaft. Next, without Pushing in, continue turning CC till it comes off.
If necessary, remove the outer indicator knob by sqeezing the two release clips in the center. This knob is keyed to only go back on one way so you don't need to remember its location before removal.
Reverse the process to install new knobs.
Oh, if you need to replace the cam or timer which are behind these knobs, the front panel will have to be removed by first removing the top cover of the washer. Now you can access the six screws inside the washer and one in front behind the detergent dispenser.
Jun 05, 2009 | Frigidaire FWT449
Needing to take off old timer knob and replace with new one
We found this on another web site:
This was super easy. If you can screw and unscrew a nut from a bolt, its that easy.
The Knob assembaly comes as a whole. So once you remove the old knob (unscrew to the Left).
Then replace the new knob assy (screw to the Right) till its a snug fit. As you will see this knob is designed to be a clockwise rotation only - normal operation - sort of a self tightening screw.
May 18, 2009 | Frigidaire Washing Machine Timer Knob -...
How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Removal of the timer knob.
you have two different knobs to replace? it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
Aug 02, 2008 | Frigidaire GLWS1339CS Top Load Washer
Replacing timer
  • push the timer in and turn it counter clockwise. this should unscrew it.
  • if that does not work, check the back of the timer for a black plastic tab. pull it out to unlock the timer knob from the timer.
  • there are many different styles of timer knobs.
Jun 29, 2008 | Frigidaire GLWS1349A Top Load Washer
Washing Machines Logo
109 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
