Question about Tally Line Matrix T6050 Printer
Backup in tally7.2
I want to know the procedure to backup in tally7.2
  • 378 Answers
At the start up screen u will see the backu p option. Just select that and then selact the destination as well as the companies to backup.
Posted on Jul 27, 2009
  • Prashant gupta Jul 28, 2009
    go to the main menu. press alt F3 then select the destination folder, After that select the companies u want to backup
How to prepare Transcend StoreJet 25M3 for use with Acronis True Image 2014 backup Software ?
The disk size of 698GB under Windows is correct for a 750GB drive.
This tells you there is only one partition on the Transcend drive.
It is best to reformat the Transcend drive to NTFS, unless you need to also read from the Transcend drive using a computer that does not support NTFS.
I would expect Acronis backup inviting you to reformat to NTFS if you would try using a FAT32 drive for backup. FAT32 has a file size limit of 4GB which may impede backups.
May 03, 2014 | Transcend StoreJet Computers & Internet
First time user - what is backup procedure?
Open up time machine and allow it to make your drive a backup. If the drive is large and you don't want to make the whole drive a backup. Whatever is a backup cannot be used for anything else until formatted. It will direct you from there.
Feb 11, 2014 | Apple Macbook Pro, -2.4GHz Intel Core 2...
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
This could be your HDD, failed. Work through, the troubleshooting procedures.
Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 14, 2010 | Acer Aspire 4315 Notebook
My playstation 3 turns off every time i go to load a game film ect, but it will stay on the home screen al day can anyone help me
Hi
Best this to do is a PS3 full reset, but make sure you back up your game data
Here's what to do:
1. Take disk out.
2. Back Up save data.
3. Back up general data using PS3s backup Utility.
4. Sync Trophies.
Now to do the ps3 reset
Hard Reset procedure for the PS3 (from Sony CS). Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
let me know how it goes.
Mar 15, 2010 | Sony Computers & Internet
How do you replace reverse bulb on 2001 deville?
2001 Cadillac DeVille V8-4.6L VIN 9
BACKUP LAMP REPLACEMENT
REMOVAL PROCEDURE
1. Pull down the rear compartment lid trim. Refer to Compartment Lid Trim Replacement - Rear in Trunk/Liftgate.
2. Disconnect the electrical connector.
3. Remove the fasteners that secure the backup lamp assembly.
4. Remove the backup lamp assembly.
5. Remove the bulb assembly.
6. Remove the bulb.
INSTALLATION PROCEDURE
1. Install the bulb into the bulb socket.
2. Install the bulb assembly into the backup lamp assembly.
3. Pull the wire harness through the body and seat the grommet.
4. Install the backup lamp assembly to the rear compartment lid.
NOTE: Refer to Fastener Notice in Service Precautions.
5. Install the fasteners in order to secure the backup lamp assembly.
Tighten
Tighten the fasteners to 4.5 N.m (40 lb in).
6. Connect the electrical connector.
7. Install the rear compartment lid trim.
Sep 11, 2009 | Cadillac DeVille Cars & Trucks
A window appears with the following message. Time Machine Error Unable to complete backup. An error occurred while copying files to the backup volume.
It appears to be a scheduled backup task not being completed.
You can disable the task by going to the backup software and removing the backup schedule.
I can't tell you the exact procedure since i don't know anything about your system.
Aug 01, 2008 | Computers & Internet
Help
Try this:
Hard Reset procedure for the PS3 (as instructed by Sony CS).
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
May 11, 2008 | Sony Playstation 3 (PS3) Console
The starup screen is not going to the main menu
Try this:
Hopefully this will solve your freezing problems.
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Tally Line Matrix T6050 Printer Logo
103 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
