Question about iRiver PMP-120 Digital Media Player
Firmware v1.10 for iRiver PMP 120 (20 GB)
I've researched this tirelessly and it all comes down to this. I just need the original v1.10 firmware for the iRiver PMP 120 (20 GB). I've read around, and it turns out it HAS to be v1.10. I don't have the receipt and the warranty's long expired, so sending it in is out of the question, so as far as I can tell, I just really need a copy of the original firmware v1.10
5 Suggested Answers
SOURCE: Iriver pmp 120
i could help you repair this email me at fatlatino26@hotmail.com i had the same problem i fixed it my self
Posted on Jun 21, 2007
SOURCE: Iriver PMP-120 will not turn on
i wos camping when my pmp 120 stoped workin so i smashd it up there and then that seemd to work lol
Posted on Jul 22, 2007
  • 556 Answers
SOURCE: boot failure
Download Adobe Reader from the bottom of the link page to read the manual
Manual and software link http://www.iriver.com/support/down_list.asp?searchProductIdx=45&searchCategoryIdx=&searchString=&page=1&idx=&tmpSearchProductIdx=45&tmpSearchCategoryIdx=&tmpSearchString=
Posted on Jan 03, 2008
SOURCE: iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Posted on Jan 25, 2008
SOURCE: iRiver H340 firmware
with the hex file hold the navi button for a few seconds; you get four options select the general one then you will see an upgrade firmware option. select this the hex file on your player is your firmware it will then go through the upgrade process. don't touch while this is happening. it will turn off when done. then thats it. Be careful the version v1.30 will get rid of the video option go with v1.29 or less
Posted on Jun 24, 2008
Firmware upgrade for PMP120 iriver
there is no firmware avail at this time but you may check time to time
  • http://local.iriver.com/usa/lounge/loungeList.asp
Jun 30, 2010 | iRiver PMP-120 Digital Media Player
My IRiver E150 4 gb blocked.It's says Generating Database.Plase wait... I wait a lot....wt can i do?
Hi, I had the same problem with my Iriver E200. The cause is firmware corruption.
I solved this problem using this method:
1) connect your Iriver device to pc and open the disc of your player;
2) you can see various folders: open the folder named "system";
3) this folder contain a *sys file;
4) open this file using notepad;
5) go to the row "version = ...";
6) you have to modify this row by inserting an older version of firmware. For example if you have "version = 1.11", insert a smaller number, for example 1.07. Save the *.sys file edited. In this way you can force iplus3 to reinstall an uncorrupted version of firmware;
7) now open iplus3, go to Tools -> Portable device -> update firmware. You should be able to reinstall firmware.
Feb 01, 2010 | iRiver E150 (4 GB) MP3 Player
My iriver got boot failure,
the latest firmware is 2.04 download HERE and follow instructions. HEREis the download link for the english version of the users manual. I hadto add the .zip extension to it to make it extract but to answer yourquestion it does not look like it supports .m4a files. Use THIS to convert yor .m4a files to .mp32_bing.gif so you can play them, it's free to try
Sep 13, 2009 | iRiver PMP-120 Digital Media Player
Iriver x20 - freezes and wont show as a connected device to pc
When you connect the PMP to the computer does it say your new device is ready for use or something else like 'the device has malfunctioned'?
I have the same issue that frequently the computer won't see the PMP. Keep trying it sometimes works. If not then its likely that the harddisk is dead or dying.
Apr 22, 2008 | iRiver PMP-120 Digital Media Player
Iriver pmp 120 use the wrong charger
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
Getting music off Iriver
Bronte,
When you change your firmware from the "manager" version to e.g. the Firmware v1.85 UMS version, you will no longer need to use the iriver manager software to move mp3's around, you can just drop them on or from your iriver. The disadvantages are that:
1. by upgrading to the UMS version, you will wipe ALL your current music, so it will NOT help you right now, only after you have upgraded to the UMS version and placed mp3's on there again. The iriver will behave like an external thumb-drive, so you can use it on any PC without the iriver manager.
2. The UMS firmware will ONLY run in USB 1.0 speeds, so it will take up to 36 minutes to fill the iriver up with 1 GB of music (or in my case podcasts).
Regards,
Robert Ilbrink
Dec 10, 2007 | iRiver iFP-799 MP3 Player
I River Idiot !
Dead Hard Drive. Thats all i can tell you. Did you hit a huge pothole or drop it today? With the way firmware is today you'll juest need to send him in. Sorry to say it, but that's the solution! thanks! Let me know of any followup needed
Jul 27, 2007 | iRiver PMP-120 Digital Media Player
Boot failure
Apr 28, 2007 | iRiver PMP-120 Digital Media Player
Iriver pmp 120
Mar 19, 2007 | iRiver PMC-120 Digital Media Player
Firmware installation crash
Check your battery capacity if its under 3.7v then you need to rejuvenate it back to that are it will all be fine.
Sep 20, 2006 | iRiver PMP-120 Digital Media Player
iRiver PMP-120 Digital Media Player Logo
814 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
