Question about E-Machines eMachines Desktop PC
Recovery reinstall can't restart - "NTLDR is compressed"
I hit ctrl, Alt, Del as instructed, but it won't restart. Goes back to same screen over and over.  I've installed several times with same result.  My hard disk is now wiped and I can't get past this issue.
Computer is e-machine W3506, XPHome, 2 gig memory.  A little over a year old.
If that item is compressed, it must be compressed inside the recovery disk because nothing is left of my system that I can reach.  Black screen.
Any hope for this poor thing?
Thanks for all suggestions.
  • 1 more comment
  • critt Dec 07, 2008
    Thanks, kornho
    Reading my message back, I see I left a lot out, though my thoughts were full.  Sorry.
    E machine, 3506.  I can't get to other info because the thing is down.
    It froze completely.  I'd been wanting to reinstall for a while to get fresh start, so I decided to do that.  I couldn't get to recovery by clicking it because everything was stuck - frozen.  I inserted the restore CD (disk) and let it do its thing.
    I didn't check for anything because I assumed it would take care of everything.
    you asked:
    >>first explain clearly how you got the ntldr is missing error.
    how do you say you completed the installation from the recovery disk?
    at what point you get the cltr alt del message after you have reinstalled the os, does it really complete the installation?
    did you check if your device has the master boot record protected while you were doing the installation... make sure the mbr is writable before you start the installation. (check your bios and set it accordingly).<<<
    The CD screen came up and asked what I wanted to do.  I chose 1st option of restoring 'safely'.  I watched it go through the format, moving files, and finishing.  It showed me a button to click to 'restart', and I did.  It blinked and came back with the message of NTLDR is depressed, hit Crt, Alt,  Del to restart.  I did this, the screen clicked, blacked out, the the G logo came back with the same message -
    I then chose the 2nd option, remove everything and reinstall.  I sat through the format, file moving and finishing only to arrive at the same message again.
    The disk is empty, but says it's full.  It was networked and I checked it on the networked machine.  My C: is RAW, and it's colored as 'full'.  Since it has not been restored there's no way I can get to anything.
    The problem is the NRLDR must be on the CD, not my computer.  I can't restart the computer to finish the install.
    Should I find a free disk wiper and try the recovery CD again?  I'll probably have the same problem though.
    Thanks for looking.lol
  • critt Dec 09, 2008
    Thanks for trying. I did reply to you with more info., but the reply added itself to the original message so you probably didn't know.
    I've given up on fixing the issue. I've asked in all the forums I could find and no one can answer. It must be a unique problem. lol
    I do appreciate your reply.
    This forum is kind of difficult to use. Where is the reply link? I must check 'Solution' or I have 'same problem'. Neither one is right. Well actually I do still have the same problem.
    I noticed there are no more than one reply on most posts, I suppose that's why. Or is it one freebie only? I don't mind paying if I was sure of good advice, but are the ones helped, being helped through private email? I see few answers as I browse the questions. I'm going to have to take it to a shop I suppose.
    Thanks for the single reply,
  • juicy reds Apr 07, 2009
    with my emachine i did whta u said above . but it does not prompt me for a administrator code
  • 781 Answers
You have a complex problem or a simple one! you may need to provide more details as we go through this (I'll try my best)
basically your system is looking in the wrong place or simply can't access the system partition (where your windows installation files are) and it could be as simple as removing a forgotten floppy disk from the floppy drive or it could be complex as to be a bios issue that may require firmware update.
let's start by checking the obvios:
1.remove any floppy disk if you have any in the floppy drive and test.
2. go into your bios and check the boot order, for now make sure your first boot device is your hard drive (the order can be changed at a later time if needed)
your recovery disk does have a compressed image of your system as it was when you purchase your computer. and that's normal.. if you did not do a backup of your files or do not have the installation cd's for your applications you pretty much have lost everything at this point but the operating system and the default programs that are part of the image on your recovery disk, and that was expected with the procedure you conducted.
post your findings and the answer and we will follow up with you.
Posted on Dec 06, 2008
  • Francisco Cortes
    Francisco Cortes Dec 10, 2008
    first of all my apologies for 2 things: 1 I misunderstood your question and 2 for the delay getting back to you.. this is a new case for me so bear with with me please:
    as I said, I had never heard of the error you had before.. so I did I little bit of digging/googling and found this:
    http://www.madboot.com/index.php?option=...
    1. you need to get a bootable windows cd. as you need to go into recovery console.. if your recovery disk is not a windows cd but an oem recovery disk you may need to get an actual windows xp cd. and follow the instructions to repair installation by entering into recovery console.. you will be prompted for user and password. enter the 'administrator' account as the user and blank for the pasword (don't type blank.. just press enter to go in, asuming you don't have a password for the administrator account.)
    2. once you're in recovery console (which pretty much looks like dos screen) enter the following:
    cd \ (press enter)
    attrib -c ntldr (press enter)
    exit (press enter)
    ..then restart
    cd \ :takes you to the root the active particion (usually c:)
    attrib -c: ntldr will uncompress the file called "ntldr" by taking the compression attribute off the this file.
    exit: simply takes you out of the recovery console.
    I hope this helps.
NTLDR is missing press CTRL ALT DEL to restart.. How to fix wothout windows xp install or program disk
Try pressing F8 just before it tries to boot, you may be able to get into your system and back up your data. Then check out flea bay for a copy of XP.
Apr 09, 2014 | Dell Computers & Internet
Can't get N180 laptop to main screen.
factory reset with f11 at startup or try reinstall windows from recovery disks
Mar 06, 2014 | HP Compaq EVO N180 Notebook
"NTLDR IS COMPRESSED PRESS CTRL+ALT+DEL TO
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
Feb 22, 2011 | eMachines T6524 PC Desktop
Issues with some programs and not able to backup. So I tried to do a restore(not a full recovery). Now it goes to a DOS screen and displays:"NTLDR is compressed, press CTRL + ALT + DEL to restart and it...
Boot from your Windows installation disk and try to repair the Windows installation. NTLDR means NT Loader,it's the primary boot file for your OS.
You can repair if it can,or re-install.Just don't reformat during the process or it will wipe everything off your HDD partition.
Bob
Aug 10, 2010 | Compaq Presario 6350US (808736414036) PC...
NTLDR is missing..how can i log-in to the windows?huhu..pls help
NTLDR is missing Press Ctrl+Alt+Del to Restart hmm..there's still no effect even if i press Ctrl+Alt+Delete..what should i do?
Aug 28, 2009 | ASUS Eee PC 1000H Laptop
NTLDR is compressed: solution not working
i think the hd is bad, better replace it and reinstall your system.
Apr 20, 2009 | E-Machines eMachines Desktop PC
Ntldr is compressed will not boot no more
Dear Friend Most common cause for your question ... some time it happend.. for replaceing Ram...
Some time It happend for.. Delete ntldr file from your C drive...
Some time it happend for Bad Sata or Ide cable,
Same time it happend for Loose connection at Motherboard to IDE device....
First step for you please reinstall the xp i think it will solved. If not please reconnect ide device.. then install Xp if needed.
Best Regards.. sumon
Mar 26, 2009 | Computers & Internet
NTRL is compressed Press Ctrl+Alt+Del to restart
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Please rate this fixya
Jan 26, 2009 | Gateway GT5220 PC Desktop
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
E-Machines eMachines Desktop PC Logo
507 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
