Question about Toshiba 50HM66 52" Television
Plaid Screen Hi, my TV was working fine. My wife turned the TV off and when I turned it on twenty minutes later, I have a plaid screen. There are squares that almost look like copies of each other. The sound is fine, but picture is messed up. I know these tv's work with multiple mirrors.....could this be some kind of mirror issue? The bulb seems fine.
  • Big Poppa Marv
    Big Poppa Marv May 11, 2010
    is a magnet by your tv?
    Genius:
  • 2,920 Answers
No the mirror would not cause the problem you are having
Posted on Dec 06, 2008
  • 505 Answers
The problem is likely with your seine board or another video board. It will have distorted video/colors and you will see copies of the image in random sizes/places around the screen. If the toshiba menu is distorted it is in later stages of video, if not then earlier. More info will narrow down exacly which board. You can try reseating the LVDS cable, the computer looking one in the middle of the tv. It goes from the video board to the light engine. Unplug the tv and take off the back. The cable is usually white and has a D-type computer like connector with buttons or screws to unlock.
I have a un75es9000f and the picture looks plaid I had some movers move it and after we hung it and turned it on it looks plaid and has a bubble on the bottom of screen any ideas of the problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Televison & Video
Dynex 37 hiss and plaid screen
There are some components that have gone bad in the board. It could also be due to moisture inside. Please do not continue to use it and refer it to a qualified service technician.
Jul 19, 2012 | Dynex "- 37"" Class - LCD - 720p - 60Hz -...
My lcd screen is plaid
Hi nailah4200, if your LCD screen is plaid , please call the lenovo support hotline 1-877-4-536686. They will check the manufacturer's warranty and if it is active, they will send that pc for depot.
Hope this helps...
Feb 28, 2010 | Lenovo 3000 C200 Notebook
Nothing but plaid on my laptop
This may be a screen problem. In order to narrow it down, plug in an external monitor. If the monitor works correctly, then it's a problem with your screen. Somethings that you can try are: With the external monitor, go in and unistall the monitor drivers, disconnect the external, and restart the laptop. Check the connections no the screen. If it's not the driver or connections, then it will be the screen and will need replacing.
Jun 24, 2008 | Dell Latitude D610 Notebook
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Green Plaid Screen
I think what you are describing is a form of line paring which is caused by a defective IC in the video circuit those inputs are feeding. Post a email link ad I will send a pic of a screen that has this problem and you can let me know if thats what your experiencing.
Jan 27, 2008 | Samsung HLP5067W Television
Green Plaid screen
had same problem with ours. at end of one year had green problem and service replaced color wheel. know 1 year after starting to have same problem again. I will not buy this brand anymore.
Jan 27, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Toshiba 50HM66 52" Television Logo
324 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
