Question about Sharp LC-19SB25U 19 in. LCD HDTV
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
    Sniper:
  • 50 Answers
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Posted on Dec 06, 2008
Sharp TV model LC-20AV1U - I need to reset it so I can get it to recognize my over air antenna after cutting cable TV
Hi Loretta,
The reason you aren't getting any channels to work on this TV is because it has an analog tuner. Now a days most channels are being broadcast in digital format and the TV needs to have a digital tuner.
In order to get the antenna to work on this TV, you will need to have an OTA converter that will receive the digital channels and send the signal in analog format to your LC_20AV1U.
Let me know if you require further assistance..
Feb 23, 2017 | Sharp Televison & Video
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
How do ihook up a digital antenna to my tv
Dominic, you do not state whether you want large outdoor antenna or simple indoor.
If you bought your HDTV anytime during the past 8 years or so, it should have a built-in tuner for receiving digital over-the-air broadcasts. If you have an older "HDTV-ready" TV that only receives analog signals, you'll need to connect it to a separate HDTV tuner.
link below tells how to install outdoor digital TV antenna.
press the helpful button.
How to Install Digital TV Antenna Digital TV Help
Jan 19, 2016 | Televison & Video
Will my TV receive digital signals without an external digital converter?
Hi, John.
No your tv is an older standard definition tv with an NTSC tuner..that was the old type tuner for analog stations.
You will need to get an ATSC digital tuner in order to tune in digital broadcasts.
Luckily, you don't have to spend hundreds to get one.
WalMart and several other stores carry inexpensive digital tuner converters that are in the $30-$40 range.
I hope this helps you out on getting stations picked up, as without the converter, your tv would only be good for hooking up a dvd player to it, or for video games.
Good luck tio you, and have a good day.
Jun 06, 2011 | Sanyo DS31520 31" TV
Toshiba Tv - Does it have a digital tuner?
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Skyassoc
Jun 22, 2009 | Televison & Video
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
I have a Casio EV-570 hand held TV. Will this work after the switch over to digital broadcast.
According to CASIO website in Japanese, their portable TVs are not supporting Digital broadcasting and decided to cease production.
Thus it will not receive Digital broadcasting.
Although, EV-570 composite AV Input should still work for Camera, VCR, etc., I have not tried to connect to the DAC box.
My portable DVD without TV tuner worked with DAC box and now can watch digital TV program!
Jan 15, 2009 | Casio EV-570 2.5 in. Handheld Television
52G786 ATSC Tuner no longer works
I have the same exact model tv...Love it...ATSC tuners is in definition an Analog tuner. As the broadcasting companies change over to Digital broadcasting before the deadline in Febuary 2009 more and more local or Non-Digital chanels are becoming obsolete. You would have to purchase a converter box for your tv if your not planning on getting cable. Another way to gois if you have an old cable line running through you house (no incomming cable) plug you tv into that jack. That also acts as a antenna. The sweet part of all this is that your tv do have a QAM tuner or Digital tuner built in just need that digital antenna to pair it up.
Dec 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
LCD TV
HD ready does not mean it has a digital tuner.
don't know what TV model you have but any TV with a coaxial connector will receive the analog broadcast. However; if your TV is not equipted with a digital tuner, you will need a set top box when analog broadcasts stop transmitting in Feb.
Aug 21, 2008 | Televison & Video
Is this tv digital ready??
Best way to tell is to hookup to rabbit ears or outdoor antenna and run the autoprogram of your channels . If you get any stations with per say 8.1 or 6.2 then you have a digital tuner . If it only shows 8 or 20 no it is just an anolog tuner . You can buy tuner that will switch the broadcast for you . Average cost is $45 to $90 . Good luck
Mar 01, 2008 | Televison & Video
Sharp LC-19SB25U 19 in. LCD HDTV Logo
356 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
