Question about Aiwa Audio Players & Recorders
Need to set time and sleep timer on aiwa cx na222 without remote.
Don't have remote for stereo and want to turn off sleep timer so stereo doesn't go off.
chris5563
  • 37 Answers
SOURCE: stereo goes on by itself
http://www.us.aiwa.com/files/manuals/omanuals/8ZNF8903010.pdf
Posted on Nov 08, 2007
SOURCE: Stereo Turns On By Itself
You must have the timer set. Press CLOCK/TIMER button repeatedly until the clock symbol or the word REC with the clock symbol disappears.
Posted on Mar 02, 2008
SOURCE: HOME STEREO SYSTEM CD PLAYER
aiwa cx-na508
Posted on Jul 28, 2008
SOURCE: Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Posted on Jan 14, 2009
SOURCE: How to play CD on Aiwa NSX-3500 (part of CX-N3500U) w/o remote control?
I thought that I had the same problem. I then discovered that when I put 3 CD's in it started up on it's own. If you push the demo button you can see how it's supposed to light up the number of tracks in a square on the right of the display. It wasn't doing that until I put in all 3. Then it started up and I was able to use the disc 1, 2 & 3 buttons to change from 1 CD to the next and I used the Up and Down buttons to change songs and the play button above the tape deck is multi-functional. Hope this helps.
Posted on Apr 27, 2009
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Does anyone know the part number for the volume control rotary encoder for an Aiwa AV-DV70U audio/video receiver? There are no markings on the component but the pc board is marked SW101. A schematic...
The EC16B24304 number above is a discontinued Alps part. I found an equivalent encoder from Taiwan Alpha available on Mouser.com, part number RE160F-40E3-20A-24P. It has the same footprint, shaft length and keying. It fits perfectly. It has a lower rotational force than the Alps encoder and 24 detents per rotation instead of a smooth feel, but it is perfectly acceptable. I just made this repair on my Aiwa CX-NA222 stereo, and I've got my volume control back!
Feb 20, 2011 | Aiwa AV-DV70 5.1 Channels Receiver
I have an Aiwa stereo cd player that only plays certain cd's but not the new ones, it is model cs-na222
Some Aiwa players will not play burned, non-closed or expanded limit cds (CD of 700MB or overburned to 750MB).
When you say new cds do you mean purchased pressed cds or ones you created?
Jun 03, 2010 | Aiwa Audio Players & Recorders
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
Remote Code Aiwa CX-NA505u
Does not play cds properly skips like crazy volume knob sometimes goes louder when i turn it down dosent read all cds eather whats the problem?
Mar 24, 2009 | Aiwa VX-S205 Combo
Nov 04, 2007 | Aiwa NSX-MTD9 Shelf System
175 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
