Question about Lexmark X1270 All-In-One InkJet Printer
Wont turn on anymore
Connecting my Lexmark-X1270 but cant get it to turn on anymore, pluged the cord to outlet and back of printer and still no power to printer, I can hear some noise on the little black box that connectes to the printer but pushing the power bottun and no luck?@!
Please help
Thanks
Kyle
    Genius:
  • 1,550 Answers
Check the fuse in the printer .
It might have blown .
Also it indicates to be some hardware problem in your printer better take to near by service center to get it checked by professionals .
Hope this helps .
Posted on Dec 06, 2008
My Lexmark X5630 does not switch on, what can I do?
1 Press to turn the printer off. 2 Disconnect the power cord from the wall outlet. 3 Gently remove the power supply from the printer. 4 Reconnect the power supply to the printer. 5 Plug the power cord into the wall outlet. 6 Press to turn the printer on.
Make sure the cord on the back of the printer is pushed all the way into the socket, it should only fit one way. If that fails, check that there is power at the outlet you are using.
Sep 08, 2017 | Miscellaneous
It wont turned on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Mar 21, 2012 | Lexmark X2500 All-In-One Printer
My printer wont turn on
Jan 22, 2012 | Lexmark X5495 Printer
My lexmark x1270 has power,but will not print from the pc
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Oct 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Yes.. I have a LexMarkX1270 Printer and I can't get the Power button to come on. I have check the power cord and witht the USB cord and they are both connected correctly. So, can you tell me with the...
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Properly secure the power cord in the power adapter. Other end should be plugged to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. Replug power adapter behind the printer and properly secure it. If printer won't automatically turn on, press the power button. If problem continues, it's a possible defective power adapter or a defective printer. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Sep 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
I need a new power cord for this printer. Where do
Take a look at the LEXMARK document: http://www.lexmark.com/publications/pdfs/1200/AMERICAS/setupsh.pdf
The power-cord is a "standard" power-cord -- nothing special.
Note the "figure-eight" plastic connector at one end.
So, look around ("thrift" stores, "dollar-or-less" stores, local electrical supply stores, and finally the "big-box" stores like BestBuy) -- it should be less than $5.
Oct 31, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer wont turn on
If you are looking at the back of the printer, just to the right of the USB port is where the power cable goes. ( o o ) <--- Kinda looks like that but vertical, not horizontal as I drew it. Hope this helps.
Jun 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Need replacement power plug for Lexmark printer X1270 all in one
Contact manufacturer. Also try e-bay. E-bay may have proper cord for less money. Be sure it come from reliable seller.
May 14, 2009 | Lexmark X1270 All-In-One InkJet Printer
Power buitton blinking and wont stop.
have the same problem. power button keeps on blinking and paper doesnt go in.
Jul 23, 2008 | Lexmark X1270 All-In-One InkJet Printer
Won't print
Turn off printer open door, move printhead with the cartridges, should slide, if not the printhead is being held in place by something. turn unit back and see if it goes back in place.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
