Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
HP Pavilion Laptop zv5000 wont power on. NOT power cord problem.
HP ZV5000. Battery seems dead, wont run or hold a charge. When plugged in, the laptop lightning bolt will light up though. When plugged in, and you hit the power button, all the blue lights on the keyboard will come on, except the hard drive light never comes on. I can hear and feel one fan turning on. The monitor never turns on. No beep, no boot to bios.
I've tried:
Plugging in CRT monitor - still no visuals.
Removing battery - running straight from power adapter.
Removing HDD, no difference.
Reseated HDD and memory.
Tried another power adapter, no difference.
Any help would be appreciated! I've built many desktops, but no experience with laptop innards. Is there an internal power supply that could be bad, or do I have to replace the motherboard?
Thanks!
Chris
  • Anonymous Mar 08, 2009
    Same problem battery ran down to 0% however, can see electrical charge, blue lights, flashing lightening bolt. All the pretty stuff, however, in about 30 to 60 seconds it was totally dead, no fans (there is two) was running. I have worked on PC's but never laptops and I remember that it was the motherboard when all signs point power supply. The cord and battery were replaced. At this point, the best advice is to buy another laptop as the Pavilion zv5000 was purchased in 2004 and it would be costly to attempt a motherboard change out. However, I will run it by the neighborhood computer shops first.
Do you have Vista? If so, you should contact HP directly. I had the same problem which occured 3 months after my warranty ran out. I called HP and was told(after they tried to sell me another laptop) that I installed the wrong antivirus program but since I never used my warranty, they would do me a BIG favor and fix it for free. I then waited 14 days for my new laptop and was very happy when it was returned only to find out 3 months later that there is a RECALL for HP laptops with the Vista program that was a MANUFACTURERS defect. THEY HAVE TO FIX IT AND FOR FREE!!!!! I hope this helps you. Good luck.
Posted on Feb 28, 2009
    Sergeant:
  • 302 Answers
I think your motherboard has gone bad, even though you hear a fan working, its just on a hot wire on the motherboard.
Posted on Dec 06, 2008
The power supply cord does not charge or supply power to the laptop. I purchased a new power cord only to find out that it is an internal issue. What part do I need to replace the internal power supply?
in all likelyhood it's the connect that the power cord plugs into. the soldering often fails in that area. it needs to be resoldered to make a good connection
Mar 28, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
ZV5120 pavilion notebook powercord not connecting
You can get an exact adapter from eBay link below, they are quite cheap. Sometimes the break is close to the end of the plug, and sometimes, the actual solder on the socket inside the unit is fractured, causing intermittent connections. Often we are able to use the old cord Plug, and graft on the new power Lead. However it is wired and regardless of how many wires are inside, the is only One - Negative, the OUTER contact. The INNER Contact is Always + Positive, sometimes there are three wire inside, TWO are Plus, and ONE, the shield, is negative.
http://shop.ebay.com/i.html?_nkw=HP+Pavilion+zv5000+power+supply+&_cqr=true&_nkwusc=HP+Pavilion+zv5000+power+supplly&_rdc=1
Mar 15, 2010 | HP Pavilion zv5000 Notebook
I cant charge my laptop and use it as the same time
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 04, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion zv5000 - No power with battery in.
the jack is the problem it is not getting enough power to laptop
Nov 02, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
No battery
check if the battery is charged fully ...?? if not try to start the laptop on Power ...and charge for atleast 1 hour...then see the backup of battery by removing power cord..
Jan 03, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hp pavilion zv5000
It is most likely a motherboard problem. You would have to take it to a service center for diagnostics. If it is the problem it may be time for a new laptop
Mar 25, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Nov 21, 2007 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
    1,206 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
