Question about George Foreman GR14BWC Indoor Grill
Non-stick surface damage
The non-stick protective coating on the grill surface has become worn, although the grill is infrequently used and cleaned according to instructions after each use, using the tool provided by the manufacturer. I can see metal showing on the grill surface - not a lot and just in one area but, nevertheless, clearly visible. The grill is out of warranty. So my concern is: Is the grill still safe to use? I understand from the call made to customer service that the grill is still safe to use and that the material underneath the non-stick protective coating is a type of high quality aluminum, which is heat resistant. However, raising a flag in my mind, is the fact that it is frequently advised on other, smaller manual appliances, such as a fry pan, to discard the cookware if the non-stick pretective coating has been penetrated and/or is worn down to metal. Therefore, I am in a quandry as to whether or not my grill is indeed safe to use. Please advise. Thank you.
  • cstaub41 Feb 13, 2008
    coating is coming off, i don't know if i want to invest in a new one if the coating does not have a lifetime waruntee.
  • 944 Answers
Contact these guys and they should be able to supply replacement grill plates cheaply; http://www.esalton.com/control/contactus In general the current view is that low quality aluminium alloys, when used for cooking can put enough aluminium into the food over a long period of time to POSSIBLY influence certain conditions such as alzheimers disease, amongst others. There is a certain amount of aluminium in many things we eat or drink, regardless of what it is cooked in. If you use the grill every day then i would recommend replacing the plates, especially if the aluminium itself is becoming pitted, however I have used similar, lower quality grills before with coating worn and haven't gone mad yet. If in any doubt then replace the plates, but i think you are being over cautious here. If you find that food is now sticking to the grill, try grilling half a handful of salt with a little vegetable oil for 10 minutes or so, spread over the whole plate - a certain amount of "non-stick" can be achieved like this, although if cleaning the plates with detergent, this will soon need doing again. Hope this helps :)
Posted on Mar 27, 2007
My Scanpan wok has bubbled on the tatanium surface I now think it is not safe to use
not ideal
the flakes and scrapings of the pans coating
will end up in the cooked food
happenes with all non stick pan surfaces
using metal utensils , over heating . age of pan
Jan 13, 2017 | The Kitchen Appliances - Others
0690005 part number
ereplacementparts.com‎
Presto Power Cord - Amazon.com
Indoor Grills in Brand:Presto ' eBay.
go to google and type in the type of grill it is with the part number and it will bring up these sites to look for a new chord.
Nov 05, 2014 | Presto 07030 1500 Watt Electric Grill w/...
I had macaroni stick in one of my pots, how do I get it clean. It's blk inside the pot,
To remove stuck on food use water (the world's strongest universal solvent). But add a degreaser. Degreasers change the surface tension of water molecules to make the water droplets much smaller. Once they are smaller they can get into areas to start dissolving what it could not approach previously. Detergent being a surfactant also allows mixing oils and water. Hot soapy water works better. We used to use boiling water in a chinese restaurant i used to work at. Boiling water helps alot. Since your food is charred it is more likely carbon sticking to the non-stick surface. Your non-stick surface must not be non-stick anymore due to using the wrong chemicals or pads on it. High temperatures make silicone type non-stick coatings fail too. If there is no more non-stick coating to worry about you could use an oven cleaner. Oven cleaners are made of caustic soda or lye. Lye is made from common table salt (sodium chloride) Oven cleaner is great at attacking carbon but not very friendly to aluminums or the finished paint on any metals on appliances. Use your own discretion.
Mar 21, 2013 | Cook's Essentials CooksEssentials 3 Quart...
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
I have a black sticky residue on the non stick surface of my cooks essentials 12 inch frying pan. I can not clean it off and the non stick properties of the pan is gone, I think due to this surface...
Go to epinions.com, type your product and find you are not alone. Besides, as there is no cure to baldness there is no such thing as a perennial non stick pan. All coatings invented eventually succumbs to the wear and tear produced by temperature changes, contact with food and related chemistry, detergents, scrapping, etc. Consider the possibility that some of that non stick material may be ingested unconsciously.
Dec 18, 2010 | Microwave Ovens
How do you Clean Toastmaster 218? what's the Trick?
Be cautious whencleaning..take note of this, UNPLUGFROM ELECTRICAL OUTLET BEFORE CLEANING. NEVER IMMERSE APPLIANCE IN WATER OROTHER LIQUIDS. ? While grids are still warm, brush with clean,soft pastry brush or cloth. ? Donot use steel wool or coarse scouring pads. Remove stubborn ? >stains with a plastic mesh puff or pad. For best results, use only products with directionsstating safe for cleaning non-stick surfaces ? Theexterior finish should be cleaned with a non-abrasive cleaner and a soft, dampcloth. ? Close latch and stand on end for storage.
Nov 21, 2010 | Toastmaster 218 Cool Touch Waffle Maker
Need to restore the non-stick surface on a GE griddle
Put a sheet of wax paper between the two plates for a few minutes while it heats up, then remove. It will transfer the wax to the grill so you'll temporarily restore the non-stick coating.
Oct 17, 2009 | GE Cooktops
Non stick coating has been damaged
toss this pan out as that damaged coating is a cancer causer.
Feb 26, 2009 | Kitchen Appliances - Others
Seasoning Waffle Baker and Grill
FIrst, make sure there is some kind of fat or oil in the waffle batter recipe. This is the biggest difference between waffle and pancake batter. Go to Sams or a restaurant supply store and get a spray product like waffle-off. Spray lightly aftter every few waffles. Use lightly as heavy spray can cause build up. If you can't find this product use one of the PAM type sprays for BBQ grills or maybe an olive oil based product. Regular Pam sprays build up faster as they are not really designed for this. Don't try to wash the grids between uses as they need to keep the oil coating. (Like using a cast iron skillet) They will turn a dark brown. Just brush off crumbs or use a damp rag. Make sure the waffles are completely cooked as when not completely cooked they will seperate and be very difficult to remove. They are cooked when the steam stops coming from the sides. This will take 3 - 6 minutes. Don't preheat with the iron open or allow it to stand open for any longer than necessary. (It can overheat)
Apr 13, 2008 | Kitchen Appliances - Others
George Foreman GR14BWC Indoor Grill Logo
399 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Marvin
Marvin
Steve Allison
Steve Allison
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
