Question about Whirlpool LSR7333 Top Load Washer
Washer not working
When I set my washer to wash it takes in the required amount of water and after that there is no operating. It is not making any sound. I remember changing from a cycle in between one the last time I used it. I changed from cycle to cyle there after and it does not respond
  • Anonymous Nov 19, 2007
    • dog paw
  • beetle baile Jun 12, 2008
    i have a similar problem with my whirlpool toploader. it works fine until it hits rinse, then it just stops and makes a faint buzzing noise. i tried cycling through all the different cycles on the dial and tried switching outlets, all with no results.
    President:
  • 878 Answers
Analisa, check this posting: http://www.fixya.com/support/t132982-washing_machine_kenmore_3_2_cu_ft_super Catriver...post back
Posted on Feb 14, 2007
My washer dryer ventless combo spins but wont drain all the water or dry. the lint trap is empty and the dryer is working but the water is not fully draining the last amount out of the machine
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Mar 15, 2011 | Equator EZ 3710 CEE / W Ventless...
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Efo error
Not using High Efficiency (HE) detergent.
Too much detergent was added.
Using too much 2X or 3X HE detergent
Solutions for over-sudsing:
  • Always use HE detergent in an HE washer. It is formulated to be a low-sudsing detergent and made especially for HE washers.
  • Be sure to use the correct amount of detergent. HE washers require only a small amount of detergent. Note: This amount may need to be adjusted for water hardness, load size, and soil level.
  • If using a 2X or 3X concentrated HE detergent, much less detergent is needed. If suds are seen, reduce the amount used.
  • If using a water softener, less detergent.
  • Make sure both Hot to Cold water hoses are connected properly at the faucets and at the washer.
Jan 13, 2011 | Frigidaire Affinity ATF7000ES Front Load...
My Whirlpool front load washer has an error code of F-20 and will not finish the wash cycle. What is wrong and how do I correct it?
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
drain_inlet_hose_wall.jpg Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
helogo.jpg See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
hcz_003_web_env1.gif If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
NOTE:The above article dircty from whirlpool customer help site.
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The code is f 20
Apr 01, 2010 | Whirlpool GHW9100L Front Load Washer
Water keep runing into the machine and exceed the required level setting. the machine will not start to washing is it that the water level in to high or does the water level setting control the washing...
put the washer on warm setting,start to fill washer,turn washer off,if it still keeps filling then you have a bad water inlet valve,if it turns off then check the water level hose from the head of the washer to the side of the outer tub,make sure both ends are on-mike
Jan 27, 2010 | Washing Machines
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
I need to use 10 gallons to have the washing machine run. If I want to reduce to 7 gallons What shall I do.(the machine is heavy duty one) Best regards, olive
The only way to use less water in a washing machine is to turn your settings down to medium or small load, this is false economy as it takes more loads of laundry to get the job done,,To use your washer to its full economy, do full loads of laundry.
The washer requires a set amount of water to run,any less and you are not going to be happy with the results.
If you have the financial resources, you can install a water reclamation system,this will save and filter and then re-use the water again and again.
Jan 19, 2009 | Washing Machines
Whirlpool duet hf error
NOTES:
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not fill before agitation
The settings on water level may be set on very low amount. Check see your water level is set on medium or full. You may be expecting the wrong amount on the low setting.
Feb 18, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool LSR7333 Top Load Washer Logo
42 people viewed this question
Sal De
Marvin
Marvin
jimorris77
