Question about Sharp R-1874 Convection/Microwave Oven
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
OVEN JUST QUIT WORKING. IS THERE A WAY TO SEE IF CONTROL BOARD IS BAD ON SHARP R-1874TF MICROWAVE CONVECTION OVEN BEFORE REPLACING IT?
    Genius:
  • 1,224 Answers
Sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Posted on Dec 06, 2008
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
How to fix Sharp Carousel Microwave Oven R-303CW clock not working?
The clock is part of the control board and cannot be repaired as a separate item. Most replacement control boards costs as much as
a new microwave.
Jul 15, 2014 | Sharp R-303CW Convection / Microwave Oven
My sharp microwave/convection oven come on, clock counts down but it does not heat nor does the turntable turn. About a week ago the breaker was tripped by it I think but it was fine until now. It doesn't...
It sounds like one of the door micro switches is bad. There are three micro switches typically. A primary interlock, a secondary interlock and a monitor switch. It is most likely the primary or secondary interlock switch. You may need to take your switches to a professional appliance shop to determine which one is bad.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 22, 2011 | Sharp R-930AK Convection/Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Why did my sharp microwave lose all power
remove cover and check small fuse, if fuse is bad it ussually is caused by a failed door switch, hope this helps
Jan 31, 2010 | Sharp R-930AK Convection/Microwave Oven
Sharp R-1870 Convection works, microwave doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
My Sharp R-1874 over the range oven quit working. Is there a fuse?
Yes. Unfortunatly, the fuse is usaully located behind the keypad mounted on a circuit board. You may have to remove a few screws to remove it. hope this helps.
Sep 26, 2009 | Sharp R-1874 Convection/Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Sharp R-1874 Convection/Microwave Oven Logo
146 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
