Question about Bose Lifestyle 28 System
Bose lifestyle DVD only playing black and white.
It was playing fine a few days ago. Now it plays in B & W. What should I do?
  • Anonymous Jan 15, 2009
    My DVD will not eject. I have pressed the eject buttom numerous times but nothing happens. I unplugged/plugged the device but no luck in getting the DVD to eject. Any suggestions are greatly appreciated.
We had the same issue. The svideo cable was no longer connected. It had become unconnected when we were connecting a game system.
Posted on Dec 20, 2008
    Problem Solver:
  • 7 Answers
Run a single cable to the yellow input on TV and connect the other end to Bose in the composite video spot #2 without the S-video adapter this works for me.
Posted on Oct 02, 2011
3 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Posted on Jul 26, 2009
MarineTech1
  • 76 Answers
SOURCE: Bose lifestyles v28 plays dvds in black and white
Check your video output settings in the menu. If you are using a composite video output and do not have the system sut up for it, you will get a B&W picture. Check your menu settings.
Posted on Aug 24, 2009
My bose lifestyle 48 say resolutio not supported when i try to play a dvd but i have sound without a picture. how can this be fixed
Is it a copied DVD or DVD-R / RW? If if says resolution not supported then it means that the DVD has a video format that cannot be played on the Bose even though the sound track is fine. The DVD may work fine on a PC as these can usually play more file types, but it could be a number of things causing it not to work and unfortunatetly there is nothing you can do.
Jun 29, 2014 | Bose Lifestyle 48 System
When playing a dvd the color is in b&w only
I have had exactly this problem when changing TVs. Initially I had the sVideo out cable from the Bose with a scart plug on TV end - that worked fine on old TV. On new TV, first Samsung, second SOny, got Black and white video picture. To get it to work I used a component video cable - this is a short svideo cable with a an audio cable at the Bose end. It splits into a 3way R G B cable within 2- 3 inches at Bose end. I then plugged rgb extension cables into this and TV and worked perfectly.
I found the answer to this by errr...... reading the BOse doucumentation I reveived when I bought the Lifestyle system 5 years ago.
Good luck
Peter
May 15, 2010 | Bose Lifestyle 38 System
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
My bose lifestyle 35 system does not play divx dvd. I do i enable divx dvd.
DivX compatibility is not a feature of the Lifestyle 35 system. You can contact Bose Support, to inquire as to whether they have any firmware upgrade for DivX compatibility. To the best of my knowledge, there is no such upgrade in existence for the LS35.
Oct 16, 2009 | Bose Lifestyle 35 System - black Theater...
Aug 19, 2009 | Bose Lifestyle 28 System
Bose lifestyle 48 dvd black and white only
Jul 26, 2009 | Bose Lifestyle 48 System
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer hello, my bose lifestyle 48 only plays DVD's in black and white. I can't find a setting or a reason why it...
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
May 31, 2009 | Bose Lifestyle 48 System
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
DVD problem - now only plays in black and white
Check the video connections on the back of the Bose unit. I have a Lifestyle 38 and had an issue with video only playing in black & white. Turned out to be a loose connection.
Nov 10, 2007 | Bose 3 2 1 GSX System
Bose Lifestyle 28 System Logo
2,021 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
