Question about GE WBSR3140DW Top Load Washer
GE topload washing maching won't spin or agitate. Where is the reset button
  • 2 more comments
  • stemisbee Dec 16, 2008
    washer fills with water and pumps water out. But will not spin or agitate the
    belt is fine. Also the motor turns by hand so it is not locked up or anything.
    Although the last few times it was running it smelled like it was burning.
  • jake1360 Jan 02, 2009
    The machine seems to work fine other then the spin cycle will not run and I to sell a burning smell!
  • Anonymous Jan 08, 2009
    washer is only 1 year old , i think the manget in the lid is not being sensed.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    There is no reset button on a GE WBSR3140DW washer. If you give me more information I may be able to help you.
    Does the washer fill with water?
    Does the washer pump the water out?
    What noises, if any, does the washer make, and when?
    Is your washer the model you posted under? (if not, please provide exact full model number)
Here's what the GE technician just did at our house to reset the electronics:
Unplug the machine for at least 30 seconds.
Plug it back in, then open and close the lid six times.
That fixed my problem. Good luck with yours.
Posted on Dec 17, 2008
Older topload maytag won't agitate , smells like burning belt
Best to look at replacing belt, but first check to make sure nothing is seized, drum spins freely etc.
Jul 23, 2011 | Washing Machines
My washer fills,will not agitate,but will spin to empty. why? #2090 ge topload
That dang drive bell has failed most likely. It has a plastic spline in it that wears smooth with time. Yank off the agitator to get to the spline. themobilian_2141.jpg
I have a service manual here
Apr 06, 2011 | GE Washing Machines
Ge toploader will not agitate
check the bell under the adgitator if ok transmission
Jun 23, 2010 | GE WDSR2080D Top Load Washer
No Spin or agitation After move
Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
Jul 27, 2009 | GE WBSR3140DW Top Load Washer
Machine does not agitate, will spin and rinse including.
Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE WBXR2060V1WW won't agitate...
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. You can get this from www.partselect.com. PS1517844 KIT - AGITATOR COUPLING
Cost is $7.15 plus shipping.
Jan 12, 2008 | GE WDSR2080D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
390 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
