Question about Vestax Pdx2000 Direct Drive Turntable System
Turntable spinning backwards
Hi I just got a Marantz TT42 in good conditions. The problem is that once turned on it spins backwards. I could not fugure out any solution (the belt looks well placed). Another problem is that it spins very very fast (I supose like 4 time faster then it should). if anyone has any idea about it... Thank you veru much
  • Anonymous Apr 20, 2008
    i got vestax pdx 2000 and when iam holding the record at the say frist beat sum times it will spin back and then go fowards over times it will just stop if u can help i b very thank full
    Novelist:
    Champion:
  • 218 Answers
If it is a direct drive TT then it uses some electronic circuitry to control speed and it sounds like that circuit is having a problem. Possibly the actual driver IC for the TT motor has gone bad. Good luck.
Posted on Feb 14, 2007
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
How to fix a motorola solid state turntable that turns on but wont spin
Hi, remove the platter and check the state of the idler wheel. Is it in good condition? Doe's it spin freely? The cause of the problem should reveal itself. Keep em spinnin, John. Stylus City
May 03, 2014 | Audio Players & Recorders
Technics Sl-1210 MkII spins backwards
As the turntable was hit hard then an internal inspection should be done to look for signs of phyical damage. It could be anything from broken parts to bad soldering or a crack on the PC board. I rather suspect it should be obvious what got damaged when you look inside.
Feb 28, 2013 | Technics SL-1210 Turntable
Has power but wont spin
Hi,Dead as in no power up or dead as in the turntable will not spin?? If the turntable isn't spinning check and see if you have a direct drive or belt driven.Getting back to your turntable, if it is belt driven your belt may have become dried rotted. replacements are available at
elexatelier.com/ ,
elexatelier.com/ or
needledoctor.com ... good luck, definitely worth getting it up and running again...
Have a nice day..
Feb 17, 2011 | Numark TT200 Turntable
My Marantz 6110 will not shut off-turntable keeps spinning after arm returns
My Marantz 6110 wasn't working right. I had it repaired at a stereo store. They told me the grease was old and had hardened which made it difficult to operate the way it was supposed to. They cleaned it and used new grease. It's been working great for the last 10 years. I hope this helps.
Dec 23, 2010 | Marantz Reference TT-15S1 Turntable
My turntable does not spin
On my Crosley there is a switch on the back for either Phono or Aux In. Make sure it is set to Phono or the turntable won't spin
Jan 08, 2010 | Crosley 0187SST Turntable
Turntable does not turn, the little brown thing turns, but when you put the glass plate on the brown thing it no longer spins.
HI. This will be the cause of a weak motor(winding failure). I recommend to have the turntable motor replaced asap. Once replaced, the table will turn properly.
Nov 29, 2009 | Coffee Makers & Espresso Machines
Defective control PC board. take in for service
May 06, 2008 | Audio Players & Recorders
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
Open Questions:
See all Vestax Pdx2000 Direct Drive Turntable System Questions
Vestax Pdx2000 Direct Drive Turntable System Logo
515 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
