I NEED TO CONNECT THE ROUTER TO KINDLE FIRE
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: How to configure our router, linksys wrt120N,
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
SOURCE: I cannot connect Amazon Kindle to my router. The
Are you using WEP 1 or WEP2 on your router? It may be that the Kindle doesn't like one or the other.
Also check to make sure that when you put the key in, you are following the case of the key, as they are case sensitive.
SOURCE: need to get my settings
Welcome to Fixya.
If you wnat to connect your Kindle to the internet you need to access the Wireless Settings Page of the router and take note of the SSID or Network Name and Network Key or Passphrase. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.0.1, the Default username is admin and the password is blank. Go to the Wireless Settings and under Security Mode you'll find the Network Key or Passphrase. You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Connect you kindle to the Network Name of your Router then if it ask you for a password then enter the Network Key.
Thanks for using Fixya.
SOURCE: WRT120N Linksys router will not
If anything it's the other way around; the blue ray player needs to connect to the wireless router / access point. Can the blue ray player be configured to work with a WEP/WPA/WPA2 secured network? Check the owner manual or go through the setup menus to see if there's a way to set up a new wireless network and configure the password for your wireless network on the blueray player. The other thing to check is to see if the router is filtering based on MAC address. You can probably disable that feature without losing much security since MAC addresses are easily spoofed.
SOURCE: I am trying to connect
first go to linksys website .Find your model and find your routers ip address or Reset router by pressing reset switch on back or bottom for about 10 seconds.Once reset is done use ADMIN in log in page with no password.then set a new password.First find your routers IP address
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
