HOW TO INSTALL A PRESSURE REGULATOR
I HAVE A FISHER R232-HBF LPGAS REGULATOR THAT IS VENTED. I HAVE NEVER HAD A VENTED ONE BUT WAS TOLD IF I INSTALL IT VERTICALLY, I WON'T HAVE TO BUILD A COVER TO KEEP THE RAIN, ETC. OUT. WILL IT WORK VERTICALLY AND IS THIS A BETTER REGULATOR TO HAVE? A LOT OF TROUBLE IT SEEM'S. - THANK'S
  • johnnymonnky Dec 08, 2008
    yes and the answer confirmed this is an upgrade in equiptment- thank's
    President:
  • 1,952 Answers
... http://meterandvalve.com/shopsite_sc/store/html/page7.html
there is one way to make this work. I feel certain that the existing system is a low pressure system. The gas company could install a higher pressure meter, and with the proper regulators this would work. We had the same situation in an airport hanger, all the heaters firing at the same time would not allow any of them to operate correctly. It turned out that the gas company had installed a low pressure regulator at the meter. After this was changed to a high pressure, and the individual heater regulators replaced, it worked perfectly
Posted on Dec 06, 2008
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Click this link for manual to "how to install"
also check this link
Before open this link u must install the adobe reader.
thanks
good luck
    Genius:
  • 1,550 Answers
Yes it is a good regulator it to reduces the chance of
blockage by freezing rain or sleet when properly installed with the
vent pointing down.
Proper installation requires the vent
to be pointed down in a vertical position. Additional protection
may be required if road splatter is a problem.
    Genius:
  • 2,920 Answers
Yes it is a better regulator and will not give you any problems with rain getting in,youll find it will work better in the long run
Need user manual for Omron HBF-302
If you haven't already tried it, Google (Omron) (HBF-302)(manual) without parens, of course.
Mar 11, 2016 | Omron Health & Beauty
Where is the fuel filter on a 2003 dodge intrepid
Removal & Installation
Print
The fuel filter mounts to the frame rail in front of the fuel tank. The inlet and outlet ends of the filter are marked for installation purposes. Install the fuel filter making certain that it is properly orientated.
NOTE The fuel filter is part of the fuel pressure regulator mounted on the fuel pump module.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Properly relieve the fuel system pressure.
  3. Lower the fuel tank.
  4. Remove or disconnect the following:
    Negative battery cable Purge and vent lines Fuel line from the pressure regulator Filter/regulator by pushing in the locking tab, turning the regulator to unlock it and pulling the it straight up
To install:
Fig. Cut away view of the fuel filter/pressure regulator
  1. Push the fuel filter/regulator into the fuel pump module and turn to lock it into position.
  2. Connect the fuel lines and install the tank.
  3. Start the engine, check for leaks and repair if necessary.
May 07, 2012 | 2003 Dodge Intrepid
1996 cherokee Country Wagon
Hi Debra: I sugges to check this procedure...
Fig. 1: TBI fuel pressure regulator
  1. Remove the throttle body assembly from the vehicle as outlined in this section.
WARNING To prevent spring pressure release, hold the regulator housing against the throttle body while removing the mounting screws.
  1. Remove the three retaining screws that hold the pressure regulator to the fuel body.
  2. Disassemble the pressure regulator assembly. Note the location of the components for reassembly. Discard the gasket.
To install:
  1. Install a new gasket and the regulator assembly. Tighten the three retaining screws.
  2. Install the throttle body assembly as outlined in this section.
WARNING The pressure regulator diaphragm MUST be installed with the vent hole aligned with the vent holes in the throttle body and regulator housing!
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 21, 2011 | Jeep Cars & Trucks
How to replace fuel pressure regulator on 1997 jeep grand cherokee
Hi Cassandra:
Check this procedure to removal and installing Fuel Pressure Regulator...
To install:
Dec 13, 2011 | 1997 Jeep Grand Cherokee
Am told that a cozymizer gas fire installed in conventional grate now requires additional ventilation. Only id marks on plate are "18N and input 9.6 kw. Can you advise?
I just happened to be looking at this site. I have just changed a Cozymiser for a Wonderfire (remote control). For fires over 7kw, you will need a vent in the room - which will cause a through draft. Our Cozymiser was 9.2 kw and without a vent, it was against regulations to use. These regulations came in after we acquired it in 1989! Our new 7kw fire is great and a vent is not needed.
Oct 10, 2011 | Heating & Cooling
I have purchased a Procom ventless heater (ML250TPA) and need to know if I have to put a low pressurer reg. on the system outside or will this model heater reduce the propane pressurer coming from my 500...
This heater is designed to work with LP gas. You will need a regulator from the tank to the heater set at 11"wc .that's standard for any LP gas system. Your existing piping system should have a regulator already outside of your house before the gas inters your home .If it does not then you will have to install one. The regulator can be inside but you will have to run a vent line in copper from the regulators vent to the outside of your house.
Hope this helps ......
Nov 23, 2010 | Heating & Cooling
Where is the fuel pressure regulator located on a 1996 jeep grand cherokee, laredo, straight 6 cyl.?
it's under the throttle body
Fig. Fig. 1: TBI fuel pressure regulator
To install:
Oct 11, 2010 | Jeep Grand Cherokee Cars & Trucks
I have a 2004 Tahoe which has misfire problems (P0300). I changed the plugs, wires, fuel filter and air filter but problem still exist. The 4 plugs on the passenger side continue to file out and become...
Removal & Installation of fuel Regulators on
4.8L, 5.3L & 6.0L Engine To Remove:
CAUTION
Three styles of fuel pressure regulators and fuel rails will be used in this model year. Each regulator has a different "footprint" that consequently changes the size of the receiving port in the fuel rail. The regulator retaining clips are specific to each rail-regulator design and cannot be interchanged.
  1. Remove the engine sight shield.
  2. Relieve the fuel system pressure. Refer to Fuel Pressure Relief Procedure.
  3. Clean the fuel pressure regulator retainer and the surrounding area.
    • Fuel pressure regulator vacuum line.
    • Fuel pressure regulator retainer.
    • Fuel pressure regulator.
  5. Remove the following parts from the fuel rail:
    • Backup ring (10)
    • Regulator Seal O-ring (11)
    • Regulator filter (12)
    • Regulator seal O-ring (13)
To Install:
  1. Make sure the NEW fuel pressure regulator retainer is the right one.
  2. The tabs (1) are used on the straight vacuum port retainer (2), and the E85-straight vacuum port retainer (3).
  3. The angle vacuum port retainer (4) has no tabs. chevy_aval15_02-04_fuelrail.gif
  4. Install the following parts onto the fuel pressure regulator (9).
    • Backup ring (10)
    • Regulator seal O-ring (11)
  5. Lubricate the fuel pressure regulator O-rings with clean oil.
  6. Install the fuel pressure regulator and retainer. CAUTION
    Whenever the fuel pressure regulator is removed from the fuel rail NEW O-rings and a NEW retaining clip should be used on reinstallation.
  7. Connect the vacuum line.
  8. Tighten the fuel filler cap.
  9. Use the following to inspect for leaks:
    • Turn ON the ignition, with the engine OFF, for 2 seconds.
    • Turn OFF the ignition for 10 seconds.
    • Turn ON the ignition, with the engine OFF.
    • Install the engine sight shield.
8.1L Engine To Remove:
Fuel pressure regulator vacuum line gm_trk_sub15_fuel_press_reg_vac_line.gif
  1. Before servicing the vehicle refer to the precautions at the beginning of thjs section
  2. Remove the fuel injector sight shield as needed
  3. Relieve fuel system pressure (See: Fuel Pressure Relieving)
  4. Disconnect the fuel pressure regulator vacuum line (A) 8.1L Fuel pressure regulator retainers gm_trk_sub15_81l_fuel_press_reg_retainers.gif
  5. Clean any dirt from the fuel pressure regulator retainer and the surrounding area
  6. Remove the fuel pressure regulator retainer (I)
  7. Remove the fuel pressure regulator (H) from the fuel pressure regulator housing
To Install:
  1. Install or connect the following:
    • Backup ring (J) on the fuel pressure regulator (H)
    • New large O-Ring (K) on the fuel pressure regulator
    • Regulator filter (L) on the fuel pressure regulator
    • New small O-Ring (M) on the fuel pressure regulator
  2. Lubricate the fuel pressure regulator large O-Ring and the small O-Ring with clean engine oil
  3. Push the fuel pressure regulator onto the regulator housing on the fuel rail
  4. Install a new fuel pressure regulator retainer (I)
  5. Install or connect the following:
    • Negative battery cable
  6. Tighten the fuel filler cap
  7. Inspect for leaks using the following procedure:
    • Turn on the ignition with the engine off for two seconds
    • Turn off the ignition for 10 seconds
    • Inspect for fuel leaks
  8. Install the fuel injector sight shield
  9. Road test the vehicle to check performance
Sep 02, 2010 | Chevrolet Tahoe Cars & Trucks
WHERE IS FUEL FILTER? 1999 HRYSLER 300M
Fuel Filter Removal & Installation NOTE: A combination fuel filter and fuel pressure regulator is used on all gas powered engines. It is located on the top of the fuel pump module. It contains a diaphragm, calibrated springs and a fuel return valve. The internal fuel filter is also part of the assembly.
To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Release fuel pressure
  3. Remove or disconnect the following:
    • Fuel Tank refer
    • Fuel tank and remove the purge line and vent line.
    • Fuel line from pressure regulator. Fuel Pressure Regulator Locking Tab dod_intrpd_fuel_reg_lckng_tabs.gif
    • Pressure regulator by pushing the locking tab in from locking slot and turning pressure regulator to unlock it.
    • Pull regulator straight up.
To Install:
  1. Push regulator down and into place.
  2. Turn fuel pressure regulator to lock it in place. Make sure take the locking tab is in the locking slot.
  3. Install or connect the following:
    • Fuel line to regulator
    • Fuel pump electrical connector into hole in the body.
    • The purge and vent lines.
    • Tank into position and install tank straps.
    • The fuel filler tube and tighten the clamp.
    • The stabilizer bar and install bolts.
  4. Lower vehicle.
    • The fuel pump electrical connector that is in the rear seat.
    • The rear seat.
    • The battery cable.
  6. Fill fuel tank. Use the DRB scan tool to pressurize the fuel system. Check for leaks.
Jul 21, 2010 | 1999 Chrysler 300M
Installing a R232-HBF REGULATOR -What's up with this screen/vent deal? Will mosture affect it?- thank's
Most all regulators require a differential in pressure to work. To get a differential, you need to have gas pressure on one side of the diaphragm and atmosphere pressure on the other side. If you have high moisture, you can either effect the differential pressure, cause a freezing condition in the regulator in cooler weather or subject the regulator to premature failure due to corrosion. You did not explain if this is going to be used in a high moisture area or not. Can the regulator be vented to a low moisture area?
Dec 05, 2008 | Heating & Cooling
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
